"Advanced HVAC Training for Home Inspectors" online video course
Welcome to InterNACHI's free, online
"Advanced Training for Inspecting HVAC Systems for Home Inspectors" video course.
Upon successful completion of this course, the student shall be able to:
- inspect heating and cooling systems;
- evaluate the basic performance of HVAC systems; and
- identify major defects common to HVAC systems.
Guest instructors are Bill Mele, an InterNACHI-Approved Instructor, who is an expert in HVAC systems and indoor air quality; and Ben Gromicko, Certified Master Inspector and InterNACHI-Approved Instructor.
And, in keeping with InterNACHI's commitment to Continuing
Education, this online training course is open and free to all Nevada
members, and can be taken again and again, without limit.
Reminder to members: InterNACHI's Code of Ethics
1.10 requires that you comply with all government rules and licensing
requirements of the jurisdiction where you conduct business.
InterNACHI's courses and Standards generally exceed the Standards of
Practice that you are required to abide by locally.
This course has been approved by:
The "Advanced Training for Inspecting HVAC Systems for Home Inspectors" course includes:
- 21 Continuing Education credit hours;
- 12.25 hours of video;
- 102,900 words of content;
- a 182-page downloadable student course book PDF;
- a 150-question final exam (drawn from a larger pool);
- instant grading;
- a downloadable, printable Certificate of Completion; and
- accreditations and state approvals.
The "Advanced Training for Inspecting HVAC Systems for Home Inspectors" course covers the following topics:
- furnaces: gas, oil, electric, solid fuel, air distribution
systems, filtration devices, classification, efficiency, components,
cabinet, valves, burner assembly, blower and motor, controls and
electronics, pilot light assembly, safety controls, igniter, flame
sensor, flame and limit controls, operation sequence, draft hood,
combustion blower, inducer fan, heat exchanger: cast iron, heavy gauge
welded, clamshell, serpentine, tubular, secondary condensing,
boilers:
classification, water, steam, fuel type, material of contruction, dry
base, wet base, water tube, fire tube, type of draft, condensing, wall
hung, integrated domestic coil, components, gas valve, safety controls,
burner assembly, heat exchanger, temperature pressure relief valve, auto
fill valve, sight glass, low water cut off, expansion tank, zone
valves, circulator pump, air separator, temperature gauge, high low
limit control, backflow preventer, oil burner, pump, blower, nozzel,
ignitor, transformer, electric motor, air shutter, reset switches, cad
cell, stack switch, radiators, convectors, finned tube, fan coil
- piping systems: gas piping systems, rigid pipe (steel), black
iron, painted outdoors, pipe dope, no teflon tape, drip leg, gas cock,
union, flex connectors, ANSI listed corrugated stainless, protected from
damage, no wall penetration, no copper tubing, hydronic, type M or L,
galvanized iron, refrigerant
- heat pump systems: reverse cycle air-conditioning system,
efficiency, defrost cycle, back-up electric heat, thermostat, controls,
standard open contact switch, magnetic strip, mercury switch, set back,
thermostat, thermostatic expansion valves, variable speed blowers, coil
design, electric motor, compressor, copper tubing, efficiency
- chimneys and venting systems: masonry chimneys, fabricated
steel stack, factory vent pipe, type B gas vent, category I, type BW gas
vent, type L, plastic for condensing furnaces, category IV, direct vent
systems, vent installations, type B vent, category I appliances,
sizing, multiple appliances, IFGC, old method, non fan assisted
combustion, minimum slope, minimum stack height, termination,
exceptions, clearance to combustibles, liners and interior flues,
cleanout, vent connector, length and height, B vent, un-vented
appliances, room heaters, free standing fireplaces, burner capacity
- in space systems: room heaters, wall furnaces, floor
furnaces, fireplaces, pellet stoves and furnaces, fireplaces, pellet
stoves and furnaces, radiant and/or convective heat, conventional or
direct vent, surface or recessed wall mount, blower, oil and kerosene
heaters, infra-red
humidification devices:
in duct, pan, spray nozzle, spinning disc, wetted drum, disc, brush,
power, bypass, wetted element, portable appliance types, commercial,
ultrasonic, electrode steam, self-contained
- central air cooling systems: refrigeration cycle, major
components, compressor, condenser and fan, metering device, evaporator,
sequence of operation, thermostat, pressure equilization, compressor
condenser, blower, condensate pump, system shut down, compressor,
hermetic, semi-hermetic, condenser and fan, metering devices, expansion
valve, piston, capillary tube, evaporator, cooling coil, refrigeration
cycle, contactor, capacitor, high pressure switch, low temperature
switch, crankcase heater, thermal overload, crankcase heater, thermal
overload, filter drier, package units
- evaporative coolers: down-flow, ground-mounted horizontal,
windows, portable, controls, components, filters, pads, reservoir,
two-stage, pre-cooler, efficient motors, water pump, blower
- defects: rust and corrosion, ignition failure, pilot
failures, thermocouples, flame sensors, combustion blowers, pressure
switches, air mixture, limit and spill switches, vent defects, too
small, too big, corrosion, improper pitch, vent termination, connector
clearance, flue clearance, liner failure, cleanouts, spillage,
barometric dampers, corrosion, blower issues, requirements, prohibited
locations, exceptions, clearances, access, leakage, relief valve
leakage, waterlogged expansion tank, high pressure, pump noise, low
water cutoff, leaky sill cock, blowdown valve, zone valve failure,
combustion air, confined spaces, poor locations, improper sizing,
ventilation problems, damper faults, spillage, heat exchanger failures,
carbon monoxide, poor combustion, air mixture, delay ignition, fuel air
mix, duct air unbalanced, duct sizing improper, defects at registers,
temperature rise, vibration, belts, sheaves, dust and debris, low
efficiency, poor selection, over sized, poor installation workmanship,
asbestos, filter problems
inspection tools: must haves, flashlight, inspection mirror,
thermometer, screwdrivers, voltage detector alarm pen, #2 straight, #2
phillips, nut drivers, 1/4”, 5/16”, CO detector, hygrometer,
psychrometer, micro-manometer, magnehelic, infra-red thermometer,
insertion thermometer, boroscope, cordless drill, cap plugs
Upon completion of this course and passing of the 150-question final exam (drawn from a larger pool), the student can
download and print his/her own Certificate of Completion, which is auto-generated in the student's own name.
The student's (InterNACHI member's) information is recorded on
InterNACHI's servers for membership compliance verification, and
automatically logs completion into InterNACHI's online Continuing
Education log. It counts as twenty-one InterNACHI
Continuing Education hours (21 CEU).
Non-members may view only the first page of the course.
Some features which make InterNACHI's courses superior to existing continuing education options:
- The course is free for all InterNACHI members.
- The course is written in pure XHTML code for quick
loading. The course loads fine on old computers and loads fast, even
with dial-up.
- The course is designed using a hierarchal menu
coupled with a sequential page navigation. This provides the student
with the option to easily repeat areas of weakness.
- The course permits the student to start, stop and restart any part of the course as often as desired.
- There are a variety of images within the course, including diagrams, illustrations and photos.
- The illustrations can be enlarged for clearer viewing by clicking on them.
- The text is integrated into InterNACHI's Inspector Glossary. Rolling over blue-colored terms provides their definition.
- The final exam uses multiple-choice questions that reference the images.
- The course's quizzes and final exam have numerous advantages over traditional exam systems:
- The course, quizzes and final exam incorporate
built-in intelligence which identifies and strengthens each student's
unique subject weaknesses.
- Not only is each question weighted with regard to
score, but each answer is weighted, as well as the correctness of each
answer being weighted.
- Answers to easy questions are weighted such that the
student is penalized, in terms of score, for answering incorrectly, but
rewarded modestly for answering correctly.
- Answers to difficult questions are weighted such that
the student is rewarded, in terms of score, for answering correctly,
but not penalized for answering incorrectly.
- Answers to questions regarding basic safety, or
questions every inspector should know the answer to, are weighted such
that the student is severely penalized, in terms of score, for answering
incorrectly.
- Upon passing the final exam, the student can print out a Certificate of Completion which is auto-generated in their own name.
recorded on InterNACHI's servers for membership compliance verification,
and automatically logs completion into InterNACHI's online Continuing
Education log.
