Mastering Roof Inspections: Asphalt Composition Shingles, Part 53
TYPES of SHINGLE DAMAGE
Creased or Broken Tabs
Once the bond of the adhesive strip is broken, wind may be able to lift and bend the shingle tabs to the point that they crease or tear.
Low-quality and older shingles will crease and tear at low wind speeds.
It’s rare that inland, non-tornado wind can break the bond of a fully bonded shingle tab. Bear in mind that just because the underside of a shingle is stained with adhesive does not prove that the adhesive strip ever bonded fully. Under certain circumstances, adhesive can be thinned by excessive heat, causing the tab to separate prior to final curing.
If a bond of the adhesive strip is broken by wind, it’s often because the shingle never completely bonded along its full length. Typically, a poorly bonded section will be lifted by wind, and this will gradually cause the remaining sections to fail. Sections of the bond may be compromised by fasteners installed in the adhesive strip or by debris.
Debris
Another potential problem with failure of the adhesive strip's bond is that debris, such as dust and dirt, may be blown into the adhesive strip. This can limit or prevent shingle tabs from bonding, leaving them more vulnerable to wind damage.
Shingles with adhesive strips contaminated by debris may need to be hand-sealed.
Shingle Blow-Off
If wind blows hard enough, it may be able to pull shingles over the heads of fasteners. Poor installation practices, such as over-driving or placing fasteners improperly, increase the chances of shingle blow-off.
Once the adhesive strips fail, the ability of the shingles to remain in place will rely more on the fasteners. If the wind blows hard enough, it may be able to pull shingles over the heads of fasteners.
 InspectorSeek.com
Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
