Oldie but a goodie(?)
Originally Posted By: bsmith
http://www.nachi.org/bbsystem/usrimages/D/DSCF00022.JPG ]
There was no TPR valve on the system. I suggested a that the buyer budget for a replacement in the near future.
Originally Posted By: abishop
What did you say in your report on this? Just curious as i had one but not sure of its age but think you got me beat. The house was a 1890’s.
Thanks!
Andy Bishop
Bishop Home Inspection, LLC.
bishophomeinspection@charter.net
269-686-6485
Quote:
The heating boiler / hot water heater is an older unit and can be considered to be nearing the end of it?s useful life. There was no manufacturers data plate on the unit so an exact determination of age is not possible. The unit and heating system performed satisfactorily when tested. Heat was located in all rooms and radiators.
There was no TPR valve on the boiler. The Temperature Pressure Relief (TPR) Valve is a safety device that prevents the pressure and temperature in a boiler from reaching unsafe levels that might cause them to burst.
The vent damper was corroded or cemented in the closed position. The vent damper is important for efficient operation of oil boilers.
It did not appear that the boiler has received service within the past year. Oil fired systems should be tuned up every year by a reputable heating service contractor for efficient operation. Most oil companies will provide a service contract with the owner to service and tune up the oil burner and provide emergency repairs and maintain the oil tanks. The burner flame must be adjusted every year, the oil filters changed, the flue draft regulator adjusted, and the flue pipe cleaned.
It is suggested that you budget for a new, high-efficiency replacement unit in the near future. A more efficient unit will help to lower fuel costs and will pay for itself over time.
Heating systems must have an adequate supply of ventilation and combustion for the heating equipment. When the heating system is located in an unconfined space such as an unfinished basement, there is generally sufficient infiltration so that air supply is not a problem. However, if the system is located in a confined space such as the area under the stairs, provisions must be made for an adequate air supply. Insure that the vents to the boiler space are kept clear.
It is strongly recommended that a competent Heating Contractor or Oil Supplier evaluate the heating system before closing.The heating boiler / hot water heater is an older unit and can be considered to be nearing the end of it?s useful life. There was no manufacturers data plate on the unit so an exact determination of age is not possible. The unit and heating system performed satisfactorily when tested. Heat was located in all rooms and radiators.
Nice quotes!
I did an Historical house the other day. Great house and well maintained but things were VERY OLD! You want to cover your butt so you need to tell them about everything but i don’t want to be too picky. But not being picky could hurt me FINANCIALLY! So i try to tell them everything butt in a way that doesn’t scare them off unless they need to be scared.
Still new at this and just hope i am doing well. No complaints yet.
Sorry for the rambling…
Thanks
Andy Bishop
269-686-6485
Originally Posted By: dvalley
Bill,
Your summary repeats itself.
David Valley
MAB Member
http://www.masscertified.com
Hi David-
Yeah I do repeat referals to specialists. I had a situation last year were a client mistook my suggestion to mean that he should do the work. He botched the job pretty bad and managed to cut his hand in the process (a simple furnace cleaning). I really don't care if clients do the work themselves as long as they understand that I referred a qualified technician. That way if Harry Homeowner destroys something they can't blame me.
