Originally Posted By: mboyett This post was automatically imported from our archived forum.
Su-weet!! Pride in workmanship shows up there doesn’t it? We have one EC here in central Texas that does almost that nice of work, Austin-Stafford Electric. Anytime I see one of their stickers that has been signed by the electrician I know it’s going to be done right and look good as well.
Originally Posted By: jkormos This post was automatically imported from our archived forum.
Oh if they all could be like that, what a pleasure to see. that is the funny thing about breaker boxes you never know until you get inside what you are going to find.
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
One problem an inspector might have with these “neat” panels.
300.34 Conductor Bending Radius.
The conductor shall not be bent to a radius less than 8 times the overall diameter for nonshielded conductors or 12 times the diameter for shielded or lead-covered conductors during or after installation.
The other one would have to do with derating conductors that are bundled together for greater than 24".
Originally Posted By: gmaher This post was automatically imported from our archived forum.
Greg,
That is exactly what my electrical inspector said when I had hime inspect the the house I built and wired, by myself. He said "this is nice, but it is too neat and your wires are bent just about too sharply" He then mentioned something about the radius of the bend and the wire w/insulation diameter determining the minimum radius to be used.
But, he did say "this is nice, but it is too neat and your wires are bent just about too sharply".
He didn't say a thing about the wires being bundled together, tho.
George Maher
Home - Safe Home, LLC
Fargo, North Dakota
In the typical residential panel it is hard to get 24" bundled together but in a large commercial panel it happens. I have had to tell guys they needed to cut the tywraps on their neat bundle and open them up a little.
... or show me their derating calc.
Usually on a 240.4(D) controlled conductor, wired in THHN you can get away with 9 before you need to derate but that is not a very big bundle.
Sometime a little sloppy is better from an engineering standpoint.
Originally Posted By: pabernathy This post was automatically imported from our archived forum.
now I know I have bad eyes and I can’t seem to magnify the image enough to see this but would Art . 250.119 as I can’t seem to tell if those wires going to the grounding bar are actually bare or green or green with yellow stripes…maybe it is just my eyes.
Also....heck I can't tell but is the GE tied through the actual nipple as I do not see anything attaching to the grounding terminal...and I cant tell if their is a lug and attachment at the nipple as well....bonding both panels.
Can you see it better than me Greg....I did notice they must have been running short on the neutral wire...lol....it is the only one not squared off...thehehehe
-- Paul W. Abernathy- NACHI Certified
Electrical Service Specialists
Licensed Master Electrician
Electrical Contractor
President of NACHI Central Virginia Chapter
NEC Instructor
Moderator @ Doityourself.com
Visit our website- www.electrical-ess.com
Paul I didn’t want to kick the “parallel neutral” tar baby but since I don’t see a ground electrode conductor I assume it is grounded/bonded in the meter base. That makes the zinc nipple a parallel path. Half the AHJs around here fail that. The rest don’t
Originally Posted By: bbadger This post was automatically imported from our archived forum.
Greg Fretwell wrote:
One problem an inspector might have with these "neat" panels.
I am sure 300.34 is not an issue here.
That looks like a 240/120 volt panel, 300.34 only applies above 600 volts. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Derating does not apply in enclosures.
I think it looks good, I do have a question of how the NMs are entered into the panel.
Personally I think its fine but it looks like the NMs are simply coming in through a PVC MA which is not an NM connector. Technically an NEC violation.
Bob, 310.15(B)(2) doesn’t say anything about exempting “… single conductors or multiconductor cables are stacked or bundled longer than 600 mm (24 in.) without maintaining spacing and are not installed in raceways…” when it points you to table 310.15(B)(2)(a).
I suppose this is another one that will depend on your AHJ.
I told y'all before about IAEI meetings where inspectors from the same department did not agree on things.
You caught me on the 300.34. Teach me to use the CDROM search ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
