Christmas Eve Question of the Day
Originally Posted By: ajalowsky
Merry Christmas everyone!
Originally Posted By: Aimee Jalowsky
The answer is grounding receptacle.
Lets see if I know why:
Ony if it has water within three feet does it have to have a GFCI.
Correct?
Originally Posted By: rcooke
I am in the 13% and I am not upset with.
Paraskevidekatriaphobia .
Roy sr
Originally Posted By: jpope
Quote:
2002 NEC 210.8 (A)(6)
Kitchens -- where the receptacles are installed to serve counter top surfaces.
All (125 volt, single phase, 15 and 20 amp) receptacles serving kitchen counter tops are required to be GFCI protected.
Originally Posted By: phinsperger
I don’t have any counter tops more than 12" wide but I do have 13 countertops that are 11" wide. They just happen to be side be side and joined together. icon_wink.gif
Jeff, I’m assuming the answer needs to be changed then?
Has it always been that way?
Originally Posted By: gbeaumont
ajalowsky wrote:
Jeff, I'm assuming the answer needs to be changed then?
Only since 1987 ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Regards
Gerry
Yes.
Originally Posted By: jsieg
Is it just me or have I been seeing a lot of Questions of the Day that had the wrong answer lately? This one had a long discussion in the BB just a couple of weeks ago didn’t it?
Incorrect answer for the Q of the D can be a good thing... It can point out who is & who isn't reading & understanding the posts on the BB.
Originally Posted By: tallen
I think GFCI "protected"receptacle would have worked nicely.
Originally Posted By: aobrien
I think having G.F.C.I in the kitchen is nice, but not required. Some people like to install them if the outlet is close to the sink (2 ft or less)
but I have not seen a split G.F.C.I receptacle. Split receptacles are needed in the kitchen to provide 2 15-amp circiuts in one outlet, to provide enough power for toaster,micro etc.
Originally Posted By: rbrown1
It all depends on which Country you live and work in.
In the States, Jeff is correct, however, in Canada any kitchen counter that is 12 inches or over and is not within (36" rule in the States) 1 metre or 39.4 inches (Canadian measurement) of a water source, must have an outlet.
The year it was installed will determine code compliance.
Safety is the key!
Originally Posted By: bkelly2
Regards
Gerry
Gerry, 1987? Are you sure?
Regards
Gerry
the sink.
Originally Posted By: mboyett
GFCI.pdf )
jpope wrote:
My info says 1996.
1987 is when they were first required for counter top receptacles near the sink.
Jeff is correct, I use the same chart kindly produced by Jerry Peck & Norm Sage, prior to 1996 the distance was within 6 ft
Regards
Gerry
Quote:
Although not required when originally built, all of the kitchen countertop outlets should be upgraded to have ground fault protection by an electrician, which is mandated by current standards and is an important safety feature.
bkelly2 wrote:
I do not understand the need for the chart? ![icon_confused.gif](upload://qv5zppiN69qCk2Y6JzaFYhrff8S.gif) If I was strictly a code Inspector maybe, but I am not. Even the bottom off the chart reccomends upgrading.
I write this for anything pre 2002
Ditto
Regards
Gerry
