curing concrete
Originally Posted By: jane molina
What does it mean when concrete is curing?
Originally Posted By: ekartal
Originally Posted By: gbell
This link should answer your questions.
http://www.concretenetwork.com/concrete/slabs/curing.htm
Greg Bell
Bell Inspection Service
Originally Posted By: rshumake
Concrete cures through a process called hydration. To cure properly it has to 1) not freeze and 2) not have the moisture in it evaporate too quickly. Either case will weaken the concrete. Hydration usually takes 28 days at which point the concrete has reached 90% of its cure strength.
Thanks all
Originally Posted By: rmoewe
rshumake wrote:
Concrete cures through a process called hydration. To cure properly it has to 1) not freeze and 2) not have the moisture in it evaporate too quickly. .
In many areas, especially out west (Low Humidity), they will actually soak the slab for several days with water. This stops the hydration from occurring too quickly, and keeps the strength of the concrete at it's highest. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Originally Posted By: James D Mosier
Soaking is pretty common in Ohio also. Not so in Tennesse?
Jim Mosier
I don’t see them doing that too much around here. We have a plenty of humidity.
Originally Posted By: jbehling
ekartal wrote:
![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif)
LMAO, sorry Jane.
Originally Posted By: rjames
I ve put up structures all over the country and I ve used water and burlap sacks but with the advent of soft saws allowing us to get on the slab while it is real green, reducing spalling. The wonders of science with all theses Cure-n_Seal products, that unless it's a small pour, 10,000 sq ft or less would not expect to see the old sprinklers and burlap.
Rick
Originally Posted By: Steve Costa
Nowadays at least in the Ohio area, the concrete is sealed soon after finishing, this slows the hydration without having to use burlap or keeping it damp with the hose.
