I have seen this home before and now I am inspecting it this week. Very old, beat up window sills, chipped paint on wall but not due to any moisture. My question is...How can I explain that these problems are not flaws and that it is just expected due to the age of the home without my client getting upset? As I already know, she expects the seller to do something about the chipped paint issue.
Thanks Scared to report |
| Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America) |
Managing your client's expectations is of utmost importance. Let them know what you do and what to expect from your report. Paint chips are normal wear and tear especially for a 120 year old home.
This may help: http://www.nachi.org/what_really_matters.htm InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Another aid:
www.nachi.org/sop.htm 1. Definitions and Scope 1.1. A Home Inspection is a non-invasive visual examination of a residential dwelling, performed for a fee, which is designed to identify observed material defects within specific components of said dwelling. Components may include any combination of mechanical, structural, electrical, plumbing, or other essential systems or portions of the home, as identified and agreed to by the Client and Inspector, prior to the inspection process.I. A Home Inspection is intended to assist in evaluation of the overall condition of the dwelling. The inspection is based on observation of the visible and apparent condition of the structure and its components on the date of the inspection and not the prediction of future conditions. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
The clients negotiations are way beyond your inspection. She is free to try and negotiate any repair or upgrade that she wishes.
As for the chipped paint. If it's due to age then say so. It definitely shows lack of maintenance as the paint is an important structural element of the home. My comment would basically describe the condition I see and what happens if it isn't fixed. I'll state that the apprarent cause is lack of normal maintenance. (given the condition you describe). I think my comment discusses that paint fails if regular maintenance isn't done. Given what it costs to prep and paint a home I would think that the paints condition is certainly pertinent to the clients decision to purchase and how much to pay. I'd say it effects the value of the property adversely so meets the definition of a material defect. As I said up front whether she decides to seek a concession over it is just is not my problem. |
Thank you for the replies.
Doug |
Older homes will sometimes have several layers of paint peeling off of the walls and ceilings. If the house is 120 years old and the interior paint is more than 25-30 years old I would have it tested for LEAD! Look for small BRITTLE sections the size of your thumbnail / fingernail and put them in a “Baggie” and send them off to a lab ASAP! Pro Lab has a good “turn-around” time. {Modern Paint will not “Chip Up”!} In case you have to send in samples from both outside the house and inside several different rooms charge your client approximately $135.00 for each “Baggie”. Be sure to LABEL each “Baggie” so you will know WHERE the sample {s} came from. A Real Estate Agent told me of a young single mother who bought a home and she wanted her son’s room and the dining repainted. The painters told her that the "Old Chipped Paint" was lead and that she would have to have ALL of the lead paint removed from the interior of the home before they could proceed. She did not beleive the painters and sent samples to the lab. They confirmed that the "small brittle paint chips" were lead. The price to remove the lead paint from both the inside and outside of the home? $27,000.00 She did not have the money and she did not want her two children exposed to lead paint so she “Abandoned” the house and is living with her parents. Now she is suing the inspector, the original owners and the Real Estate Agent {S}! I say…. Be CAREFUL …. Protect your client and…. PROTECT yourself from a future lawsuit! Good Luck! Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 |
Steven C. Meyer is a non-member guest and is in no way affiliated with InterNACHI or its members.
If she wants a "perfect" house, tell her to buy a new one, and wish her good luck.
To me, the paint condition comes under cosmetic, just as worn or ugly carpet, worn hardwood floors, cracked counter/ floor tiles. What you see, is what ya get!! Virtually ALL older homes will have lead paint, and note that possibility, just as you would the possibility the old "popcorn" ceilings "may" contain asbestos. Cosmetic issues are between buyer and seller, believe that is called necogations. Let the realtors hash that out, that's what they are being over paid to do. |
Unless you are certified/licensed by the state of Ohio (I see you are in Ohio), you would be well advised to refrain from actually performing ANY "lead testing" OR "sampling"... that "$135 baggie" or $25 swab could cost you thousands in fines otherwise.
Just my word to the wise. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
I am sure that if you go to your local Home Depot store you will see “Kits” for the collection of Lead paint chips, asbestos, mold, radon in air, and for testing your water supply. MOLD & ASBESTOS Just to be clear..... Although "Home Owners" use these kits to collect and send in “Paint Samples to Certified Laboratories / Testing Facilities on a regular basis .... I strongly recommend that each and every Home Inspector who suspects Asbestos, or Mold in a Home have samples collected by a "Certified / Trained" inspector. NOTE: I do NOT advocate disturbing / loosening ANY suspected asbestos fibers when and IF you ever collect anything on a job site.
Did someone REALLY say this up above:
"the paint is an important structural element of the home." - Erby Crofutt B4U Close Home Inspections Georgetown, Kentucky KY Lic# HI-2041 www.b4uclose.com http://www.kentuckyradon.com Kentucky Home Inspections Kentucky Home Inspectors NACHI02090301 "LIKE" me on Facebook Kentucky Homeowner Resources @ http://www.kentuckyhomeinspections.com BLOG by Erby, The Central Kentucky Home Inspector Join Active Rain HERE |
"It's not what you believe that matters...it matters what you believe!" |
http://www.odh.ohio.gov/odhPrograms/.../lp_prev1.aspx
http://www.odh.ohio.gov/odhPrograms/..._prev/law.aspx Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
General provisions and prohibitions according to the Ohio administrative code
http://www.odh.ohio.gov/ASSETS/45B89...24/Fr32_03.pdf Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
As my termite inspector said: "The only thing holding this house up, are the termites holding hands!!" |
Well it looks like we are on to something here and I will have to simply add that as an older home, it may be subject to lead paint and asbestos to save my butt. By the way does anyone know how old a home has to be to be "free from lead and asbestos"?
Doug |
| Orange County Home Inspections | whandley | California Inspectors | 12 | 5/18/11 6:35 AM |
| Buyers Best Home Inspections | ddinwoodie | Miscellaneous Discussion for Inspectors | 6 | 9/4/06 7:20 PM |
