View Poll Results: 2 general inspectors 1 client/house. Would you do the inspection?
Yes 42 62.69%
No 11 16.42%
Just do radon and WDI 2 2.99%
No way Josie seems like trouble 14 20.90%
Multiple Choice Poll. Voters: 67. You may not vote on this poll
Old 5/8/09, 12:38 PM
David C. Macy's Avatar
Default 2 Home Inspectors 1 House
I went to set up my radon test(s) for the home I am scheduled to do an inspection on Monday. To my surprise my client was there and they were having it inspected by another company.
She states she wants to have both inspections so nothing is missed.
The client is extremely cautious as they have a small child that has health issues.
They rehabbed the home recently. She is having 2 home inspections, A mold inspection, 2 radon tests(Wanted 3) and a WDI inspection.
I told the client you really do not need 2 home inspectors. You should place your trust in one or the other. (She is not using the Realtor inspector) (Realtors are both tired of dealing with her and her agent did not show for the 1st inspection)
Now she insists I do the general inspection on Monday! I reluctantly agreed.
She stated one item the other inspector had stated to her. "The air conditioner is to big"
Now I was curious and looked at the data plate. 3 ton system, 2 story house with a recently finished basement.
My 1st question is when did general inspectors start determining the size and adequacy of the cooling system? To many variables that need to be properly calculated by the trained HVAC specialist. (Insulation, windows, square footage)
2nd question. See poll.
Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America)
Old 5/8/09, 1:03 PM
Kevin M. Leonard's Avatar
Kevin M. Leonard Kevin M. Leonard is offline
Default Re: 2 Home Inspectors 1 House
No-way Josie. Either she is wanting out of the contract, has devious intentions or she is just plain paranoid. I personally would decline.
Kevin M. Leonard
The Ohio Home Inspections Company
513-895-7700
937-283-5118
Old 5/8/09, 1:12 PM
Marcel Gratton's Avatar
David,
I would do the inspection.
I never claim to be perfect and explain to the customer that a home inspection will reduce risks in purchasing a property and not eliminate it.
Can't blame the client for being cautious, it is usually the biggest purchase of their life.
Now, if only they all could afford two, three inspections
On The Level Inspection
Gatineau, Québec
Old 5/8/09, 1:40 PM
Is she having you do all the Radon tests & at different times?
Most here know how I feel about the mold issue. I wouldn't even begin to go there.
Sounds like a great idea upfront. More work for all inspectors. Until you end up in court with one inspector being pitted against the other.
Usually the motto is "Buyer beware" In this case I would say "Inspectors beware".
If you do the inspection. - CYA
Kevin M. Leonard
513-895-7700
937-283-5118
Old 5/8/09, 2:22 PM
I am doing both radon tests at the same time. My client actually wanted another monitor as well. The home has a basement and she also wanted the room where the sick child will be in.
I understand her concern for the child.
Yes they are paranoid but if I had a kid that was in and out of the hospital every day with a kidney transplant I to would be paranoid.
My client had a bad inspection on her exzisting home and wants to be extra cautious.
One thought I had is on the 2 general inspections. I wonder what kind of negotiating she will have if there is a problem.
Like one guy states air conditioning over sized and I may state operated properly when tested.
I am going to do the inspection. I guess I see the best in people and want to help my client and ill child.
I feel confident in my ability as an inspector and I document my reports to current conditions and limitations. I spend 5 minutes creating a diagram of the visible foundation. I make my reports as if each one is going to a lawyer. (Or at least I try to)
Like basement recently finished with an interior basement drainage system with a warranty. Now I was not even looking but, original exterior drainage, numerous walks, patios, ground improperly sloped torwards house, large trees in close proximity of house.
Siding appears to be installed by an ametuer, Inquire with local jurisdiction on history of permits. Recommend a qualified specialist to repair or replace before close of escrow. Now if the other guy found the siding to be Satisfactory good luck to the client in negotiating.
Old 5/8/09, 2:41 PM
I see your point David, With a sick child I can understand them wanting to be "extra" cautious.
Kevin M. Leonard
513-895-7700
937-283-5118
Old 5/8/09, 10:35 PM
I would do it in a heart beat David. Go for it and do what you know best.
The most accurrate and precise information provided by a Inachi Inspector.
Now you are in competition, what else could be more interesting than that to show the client you are the better of the two. A challenge, allright, go for it. I love it.
Update on your inspection is mandated by this board. You hear.?
Marcel
Old 5/9/09, 1:44 AM
Russel Ray's Avatar
I would have no problem doing the inspection.
Old 5/9/09, 1:53 AM
Nick Gromicko's Avatar
Now if you had 3 inspectors it would be called a gangbang.
Find a Home Inspector
Old 5/9/09, 6:33 AM
David P. Valley's Avatar
Let me loose. I'd perform the home inspection without even hesitating.
Old 5/9/09, 6:33 AM
Marcel
I am ready for the challenge.
Old 5/9/09, 6:34 AM
RR has there ever been a time that you have walked away from an inspection?
Old 5/9/09, 6:36 AM
If you add the mold inspector then it just may be!!!
Thanks when I read your post it made me laugh.
Old 5/9/09, 9:58 AM
Joe Funderburk, CMI's Avatar
Show me the money!
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 5/9/09, 11:26 AM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
End Quote:
I have been in business since 1972 and NEVER had a complaint filed against me.
Yet …… I have been to 114 Trials, depositions and Arbitration meetings. Why?
Because…. I was providing Expert Witness testimony against builders, contractors, Real Estate Agents, and sadly some people who thought that since they had been in the construction industry for some time and had a “Ladder & a truck” that they were qualified to be a “Home Inspector”.
Needless to say these people MIGHT have been good roofers, plumbers or painters but…. They did not have the slightest clue as how to inspect an entire house and the systems / components that they were unfamiliar with.
Their so called check-list reports were a joke!
We live in a litigious society…. IMO… I “ALWAYS” write each and every report like “It is going to court”.
With two inspectors writing two different reports….. I think that you probably have a “law suit waiting to happen” and I would act accordingly.
Good Luck!
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Washington Home Inspections sstanczyk Miscellaneous Discussion for Inspectors 8 9/2/06 2:53 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Home Inspector Listings Part Two jbowman Miscellaneous Discussion for Inspectors 8 8/29/06 8:52 PM
