Old 9/22/06, 2:31 PM
William E. Billings William E. Billings is offline
Default 4 point
Does anyone use there own 4point inspection form to these inspections and would you share a sample copy for me to study. Some of these insurance ones are soooooo long to fill out.
Thanks;
Bill
www.billingshomeinspections.com
Old 9/22/06, 3:06 PM
Charles R. N. Crooker's Avatar
Charles R. N. Crooker Charles R. N. Crooker is offline
Default Re: 4 point
Thanks;
Bill
Bill you have mail, I could not fiqure out how to get the form to go here so I e-mailed it to you. Hope it helps.
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
Old 9/23/06, 10:35 PM
Lawrence G. Harrington, Jr. Lawrence G. Harrington, Jr. is offline
Default Re: 4 point
Hi Charles,
I'm in the same boat. Do you mind sending it to me too. I would greatly appreciate it. Thanks
Old 10/3/06, 10:47 AM
Curtis Petty Curtis Petty is offline
Default Re: 4 point
Charles,
While you are sending the 4 piont how about sending one to me as well!
ahomeinspection1@yahoo.com.
Thanks,
Curtis Petty
Old 10/3/06, 12:23 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Re: 4 point
The key to having a successful four point report is to keep it simple. Any report that is to complicated will be returned. I would suggest that you tell clients that have their own form that you have your own and will use it for them to submit. If your form comes back for any reason then you will deal with it at that time. As long as your form is simple and you have the right credentials it should not come back. At least that has been my experience.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 10/3/06, 10:06 PM
Default Re: 4 point
Originally Posted by lharrington
Hi Charles,
Lawrence you have mail.
Old 10/3/06, 10:08 PM
Default Re: 4 point
Originally Posted by cpetty
Charles,
Thanks,
Curtis Petty
Curtis you have mail too. Let me know if it is what you wanted or needed.
Old 10/9/06, 7:56 PM
Default Re: 4 point
What is a 4 point inspection?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/9/06, 8:41 PM
Default Re: 4 point
Kenton;
I believe that is when you make a quick inspection from the outside and look at all four elevations of the house and debate whether you want to go further.!!
Marcel
Old 10/9/06, 9:00 PM
Default Re: 4 point
I see. So the form has an "N" at the top, an "S" at the bottom, An "E on the left side, and a "W" on the right side, just so you don't get confused about which direction you're facing as you make your decision.
(303) 717-8940
Old 10/9/06, 9:27 PM
wforsyth's Avatar
wforsyth wforsyth is offline
Please Note: wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: 4 point
Usually the 4-point is four major systems in the home. Foundation, Roof, Hvac, and Electrical. But I've seen variations of it depending on the inspector.
Old 10/9/06, 9:29 PM
Default Re: 4 point
What's the advantage?
(303) 717-8940
Old 10/9/06, 9:35 PM
wforsyth's Avatar
Default Re: 4 point
I am not doing them yet, so someone else will have to answer that. It seems to me that they are quicker, easier, and less liability since you are limiting the inspection. However, I am sure someone else will have a first hand experience that is more accurate.
Old 10/9/06, 11:30 PM
bsumpter bsumpter is offline
Default Re: 4 point
I believe Russel Ray did this level of inspection begining last year...but I could be wrong.
Old 10/12/06, 6:40 PM
cobarr cobarr is offline
Default Re: 4 point
Ditto.
By all means report any safety issues, "MAJOR" areas of concern, that's what the carriers want to know, (along with estimated life expectancies). Simple is best.
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 10:19 AM
