Go Back   InterNACHI Message Board > General > General Inspection Discussion
Old 1/16/09, 9:50 AM
Donald E. Viehman Donald E. Viehman is offline
Default 4-Point inspection
While doing the plumbing part of the 4-point inspection, does anyone check the washing machine pipes and drains by running it through a rinse and spin cycle?
Old 1/16/09, 9:56 AM
Gerry Beaumont's Avatar
Gerry Beaumont Gerry Beaumont is offline
Default Re: 4-Point inspection
Absolutely not, the 4 point is a visual inspection only designed to report problem materials and obvious failures.
Regards
Gerry
Virtue is more to be feared than vice, because its excesses are not subject to the regulation of conscience.
Adam Smith (1723-1790)
NACHI cell 484-429-5466
NACHI02121106
Old 1/16/09, 9:40 PM
Thank you Gerry, We had not been checking that, just wanted to make sure...
Old 1/17/09, 7:47 AM
William E. Siegel William E. Siegel is offline
you do remove the electrical panels, right??
Bill Siegel
Florida Home Inspection Team Inc.
Old 1/17/09, 8:13 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Why would you remove the dead front?
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 1/17/09, 11:03 AM
Yes I do take off the dead front so I can report the wiring types, and improper connections.
Regards
Gerry
NACHI02121106
Old 1/17/09, 5:59 PM
Joseph T. Burkeson, CMI's Avatar
Joseph T. Burkeson, CMI Joseph T. Burkeson, CMI is offline
Do you walk the roof?
"I know of no more encouraging fact than the
unquestioned ability of a man to elevate his
life by conscious endeavor." ~ Henry David Thoreau
Certified Master Inspector (2007)
Member, International Assoc of Certified Home Inspectors (InterNACHI)
Member, International Code Council (ICC) - Certified Residential Combination Inspector
Member, American Society of Home Inspectors (ASHI)
Vice President - Suncoast ASHI
Square-One Inspection "Assurance begins here"
Old 1/18/09, 10:12 AM
I do. How else can you determine the condition and age. I went up on one once where the front of the roof was replaced but the back was not (old and shot). You would not have been able to see the back roof with getting up there. And the flat roof on this home was done with shingles
Bill Siegel
I agree with Gerry 100%.
Bill Siegel
Old 1/18/09, 10:16 AM
Too many inspectors take these inspection lightly. When something goes wrong in a home that had a four point inspection done, who do you think the insurance company is going to come back to, not to mention the homeowner.
Bill Siegel
Old 1/18/09, 10:22 AM
David P. Valley's Avatar
William,
You bring up a very good point. Always attempt to observe (and report on) all sides of a roof.
I had one inspection of a home (on a hillside) where I couldn't access or observe the rear portion of a roof and there were trees that were blocking my view from observing this particular roof. The front field was newer, but I wanted to make sure that the rear field matched.
I got on the adjacent roof and look what I found...note the newer shingles at the ridge.
Old 1/18/09, 11:05 AM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Why would you not?
Bill Boerner
St. Louis,MO - Professional Home Inspector
STLhomeinspector.com
All of metro St. Louis including all surrounding Areas Customer Testimonials
Home Inspector Pro Software - A Professionals choice in software.
Old 1/18/09, 11:16 AM
Doug Edwards,  CMI's Avatar
Had exactly the same thing happen to me. The sellers had received money from their insurance company to replace the roof after one of the major hurricanes had damaged theirs. They replaced all the shingles on the front, then tried to used caulk to fill the hundreds of holes in the back where they had a blue tarp roof from the FEMA crews. Had I not got on the roof I would not have found that out. The roof was leaking inside a couple of the interior closets. Buyer was so pissed she walked away from the deal because of their dishonesty. I pull dead fronts as well and on these older homes more often than not I find problems that should be identified. The item on the forms "Any exposed or unsafe wiring? means just that. How can you observe the panel ground without making a point of looking inside the panel?
Doug Edwards, CMI
Old 1/18/09, 12:10 PM
Hi to all,
Yes I normally walk the roof, unless it's too steep or to high, but as most of mine are low pitch single storey then I walk them. To be honest by the time I have my ladder at the eaves to get an idea of condition, it only takes a couple of mins to get right up there and do a more thorough evaluation.
I don't walk the tile roofs at all on 4 point inspections, but I will get up to the eaves at a few different locations, especially the valleys to look at the flashings.
Regards
Gerry
NACHI02121106
Old 1/18/09, 5:31 PM
Just out of curiosity, how many of you report fuse panels that have been improperly converted to breakers by just changing out the bus bar
Bill Siegel
"UFER" Ground? see last paragraph. jtedesco1 Electrical 6 9/15/08 8:57 AM
What is a Point Well? mjohnson6 Plumbing 5 8/19/08 10:11 PM
What's this video worth? jtedesco1 Education 5 4/18/08 10:24 AM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical 1 4/22/06 11:19 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
