"for calif." Does anyone know a quick way of telling air cond. and heat pumps apart? Please keep in mind I'am new at this.
Look for an accumulator and a reversing valve in the unit near the compressor.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
OK, got it blaine. Thank you so much!
thanks Blaine!
Take a quick look at the thermostat inside and if you see an "emergeny heat" switch... that's a heat pump.
I was thinking that as I was typing. Yes, it's a tip-off but you do need to look further for sure.
If I'm not mistaken, the AC will have a large and a small pipe, where the heat pump will have the same size pipes. I did find this site with some good diagrams. www.dhclimatecontrol.com/hp.htm
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Turn on the heat and feel the big pipe.
If it's hot, it's a Heat Pump. |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 11:47 PM |
| Carrier heat pump fires? | lprinzi | Inspecting HVAC Systems | 3 | 10/12/06 8:31 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 1:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 10:17 PM |
| Heat Pump Check list for inspecting | dmacy | Inspecting HVAC Systems | 21 | 2/1/06 1:56 PM |
