Does anyone out there do air pressure tests for plumbing at all or everytime you inspect. This is not something I have done or that I want to do each time because it seems to be something that a plumber would be more suited for.
Am I completely wrong in that statement? I do water pressure tests for the psi. But is anything beyond that out of the scope of the inspection? I just want to know if this is something I should or shouldn't be doing. Thanks |
I only test the PSI.
If you are speaking of the supply side, it is already under pressure when the water is on.
If you are speaking of the drain side, you would have to cap the vents, all drains, etc., then pressurize. This is something a plumber would do, not a home inspector. Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Yee haw!!!:d
I have to agree with Blaine. Not really a home inspectors area, don't you think. Call a plumber if that's how they want it tested, offer to tag along with him, if you want to get into this later on. I wouldn't touch it though. Good luck Scott.
I would not and will not do it. I have a realtor asking if I do it because of a nightmare client she is dealing with.
I deferred it to a plumber. Thanks for all the replies! |
Ian, I'm coming up for the InterNACHI seminar in Milwaukee on the 24th. If you are going, maybe I'll see ya!
Later |
Scott, this is a test that has to be preformed by the plumber in order to pass the code inspectors test . as a HI it is not necessary , if you are inspecting a new home then get with the plumber and let him show you how this is done. again after the system has been pressurized you would see any leaks because it's under water presure just test the water pressure using a water pressure gauge at a faucet . good luck
"Sure I'll 'have' a pressure test done on the plumbing for you. I'm in the middle of something right now, but can I give you a call back in just a little bit with an estimate for an inspection that includes that?..."
I'd then get on the phone with a local plumber and find out how much he would charge me to sub the plumbing component of the inspection including a pressure test. I'd tack that price on to the top of my regular inspection price and call the guy back. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I've done the water psi test on request on a client. Do you do the water psi test on every inspection....?
John R Fordyce Safe-Buy Home Inspection Pittsburgh Home Inspection NACHI #06051992 724-463-SAFE Pennsylvania Home Inspector Pittsburgh Home Inspector Internet Marketing Consultant for Home Inspectors >> Beat the Realtors <-> Book New Clients Before They Ever Hit the Real Estate Office >> |
I do
I used a pressure/flow meter on every inspection and then took a picture of the meter.
Thanks.... John R Fordyce Safe-Buy Home Inspection Pittsburgh Home Inspection NACHI #06051992 724-463-SAFE Pennsylvania Home Inspector Pittsburgh Home Inspector Internet Marketing Consultant for Home Inspectors >> Beat the Realtors <-> Book New Clients Before They Ever Hit the Real Estate Office >> |
I lived in Chester County, PA which was mostly on private wells. Today I shot a show for www.NACHI.TV on using pressure and flow meters on an inspection. It will air in March.
kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Same here.
| bbbb | mcyr | Structural Inspections | 1 | 8/19/07 11:26 PM |
| Hydrostatic Pressure Test | Edward D. Wend | Plumbing Inspections | 9 | 6/5/07 4:58 PM |
| air pressure test vs. hydrostatic pressure | mcyr | Plumbing Inspections | 22 | 7/11/06 7:11 PM |
| water pressure test | msaxton | Plumbing Inspections | 27 | 2/13/06 12:58 AM |
