I found what I suspect is aluminum branch circiut wiring, but I cannot confirm it. Should I report it as "suspected" aluminum and suggest further evaluation by licensed electrical contractor?
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The first image looks like tinned copper.
I am not aware of any single strand aluminum wire with anything but TW insulated in a plastic jacket More info here: http://www.inspectapedia.com/aluminum/aluminum.htm http://www.inspectapedia.com/aluminum/ALid16.jpg InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Yep, tinned-copper.
This should reported as well. The sheathing on this wiring deteriorates, exposing the conductor. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks for the help and the links. I love inspectapedia. I have seen a lot of great info there.
Thanks you both again for enlightening me about the tinned copper wire. That maybe explains the other issue I found in the house. On that circuit, there was a segment of conduit that was energized. I thought that maybe if that was aluminum wire that maybe it came loose and was touching the conduit. But the light at the end of the circuit was still working, so that didn't really make sense. But if the sheathing has deteriorated to expose the conductor like Jeffrey described, that could maybe do it, right? But wouldn't that cause arcing?
This is only a practice inspection and it is a friend, so I may have the opportunity to remove the wire from the conduit to see what's going on in there. Thatnk you both again for you help. I am loving the NACHI community. |
Is the only way to tell it is tin clad copper by the cloth sheathing?
Michael Merino Merino's Home Inspection & Education Inc. "Not just an Inspection, an Education"SM Phone/Fax 708~535~6057
It's probably the simplest, but certainly not the only. The cloth-covering is a dead give-away, but you can also see copper at the cut end of the conductor or in any nicks in the wiring.
Ins't the tinned copper in bx also?
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
Ironic, I just did an inspection, and wouldn't you know it, tin clad copper. I could see the copper through the nicks in the wiring. The cloth sheathing was deteriorated. Old panel with fuses.
Sort of like this?
| Evaluating your home's wiring system | mcyr | Electrical Inspections | 0 | 12/30/09 2:31 PM |
| Aluminum Wiring | jhagarty | Electrical Inspections | 23 | 10/5/07 3:56 AM |
| Aluminum Wiring | acox | Electrical Inspections | 4 | 8/27/07 12:24 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
