Old 6/9/07, 1:15 AM
cdammann cdammann is offline
Default Another New Guy...Palm Tech's list vs SOP
First...thanks for all the tips for improving my web site...it's now web site of the week... www.InspectorDammann.com
I will be using Palm Tech's Palm-Tech Inspector V5. It seems like there is a lot more stuff in it's templates than is necessary. I printed out a hard copy of all the items it has listed and am comparing it's list with the do's and don't have to's on the NACHI SOP.
A simple example is fences. The SOP says we don't have to inspect fences, but fences are in the Palm Tech's default list of stuff to check. There are other examples as well, of things that are not on the SOP but in the Palm list. And vice versa.
Should I just edit the template and delete stuff that's not necessary, and add stuff that's not there but should be? It seems like it might be riskly to comment on anything more than is necessary.
Old 6/9/07, 10:10 AM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
Default Re: Another New Guy...Palm Tech's list vs SOP
Chris certainly you may do whatever you like - but a few comments - food for thought.
There are two ways to look at the SOP.
1. It is the "minimum" standard of practice.
2. An inspector may exceed the SOP where the inspector has knowledge, skills or expertise in the subject area.
The issue is a fine balance between managing "risk" or dealing with ones "duty of care". If the fence is there, and obvious defects are visible - what harm is there is noting such conditions? Now you can claim that you went above and beyond the SOP - in the best interest of your client.
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 6/9/07, 11:02 AM
Russell Spriggs's Avatar
Russell Spriggs Russell Spriggs is offline
I respect the thoughts of those who look at it as a "minimum", but I don't agree with them.
I look at the SOPs as an Umbrella of Protection, because that's what my insurance covers -
no more, no less.
My report in in conformance with our SOPs. No more, no less.
Old 6/9/07, 1:22 PM
Ok, thanks for the info
Old 6/9/07, 1:23 PM
Ok, thanks.
Old 6/9/07, 3:38 PM
Nick Gromicko's Avatar
Taking our SOP Quiz will let you know if you are over or under inspecting to SOP http://www.nachi.org/sopquiz.htm
Find a Home Inspector
Old 6/9/07, 9:36 PM
I'll check it out..is that the one that's on membership check list about 7 or 8 from the top ?
Old 6/14/07, 12:51 AM
Peter Doane's Avatar
Chris,
I use palm tech too. Their templates are basic at best. I've created my own templates from scratch to suit me and to make it unique. 5V allows you to delete lines, create lines and categories and save what you created as a new template. Good luck to you.
Peter Doane
NACHI ID# 05120681
Old 6/14/07, 6:48 AM
James H. Bushart's Avatar
Chris,
"An inspector is not required to inspect...." does not necessarily mean you will not or cannot.
You base your fees upon the SOP. When your client requests additional items to be inspected, and you are able to do them (for some may require licensing or other credentials), you add them to that particular inspection....at an additional rate....making note of this modification to the SOP in your agreement.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 6/14/07, 9:21 AM
Joseph Burkeson, CMI's Avatar
Joseph Burkeson, CMI Joseph Burkeson, CMI is offline
But fences do count if they are attached to the dwelling and they are negatively affecting the structure or somehow encumbering an emergency egress.
"A state of war only serves as an excuse for domestic tyranny." ~ Alexander Solzhenitsyn
Certified Master Inspector (2007)
Member, International Assoc of Certified Home Inspectors (InterNACHI)
Member, International Code Council (ICC) - Certified Residential Combination Inspector
Square-One Inspection "Assurance begins here"
Old 6/21/07, 12:17 AM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
no more, no less.
Oh, it's a minimum SOP to be sure...
You maybe in compliance or conformance, but so are many other inspectors who exceed the NACHI SOP. The SOP uses the following terms:
The inspector is not required to:
The inspectors are not required to determine:
The inspectors are not required to operate:
The NACHI SOP does not use the term:
The inspectors "Shall not":
The NACHI SOP also lists the following items for example which I'm sure we've all tested or moved:
III. The inspectors are not required to:
A. Move any personal items or other obstructions, such as, but not limited to:
1. Throw rugs.
or
II. The inspectors are not required to operate:
A. Any system that is shut down.
B. Any system that does not function properly.
C. Or evaluate low voltage electrical systems such as, but not limited to:
1. Phone lines.
2. Cable lines.
3. Antennae.
4. Lights. (Personal favorite)......
or
M. Research the history of the property, report on its potential for alteration, modification, extendibility, or its suitability for a specific or proposed use for occupancy.
I'm paid thousands of dollars each year for researching building permit histories for the expert witness and or construction defect cases I'm involved with.
As RR routinely states the various model building codes are "Minimum" code requirements. And I believe all inspection organization SOP's are minimum standards as well.....
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 126 4/27/07 11:05 AM
