Would you concur that these do not look like carpenter ants, but "regular" ants?
Just a thought, wouldn't it be great to have a separate heading on the MB for crawlspaces and attics (possibly basements) that aren't related to structural? It seems that there are many posts about these areas. |
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I did a large 2+1/2 storey house a few years ago on which we saw 2 lines of ants going up the outside towards the attic area. Took samples to entomologist at the local Natural History Museum.........there were actually 2 different species of carpenter ants. |
Can't tell from the pic. If you look at the body of the ant, a carpenter ant will have a smooth back, where a field ant will loof like it has a hump in it's back.
On a side note, unless you are licensed in Ohio to perform these inspections for WDI, I would not use the word carpenter ants. Note that ants were seen and refer it to a specialist. Here is a link for Ohio license information. http://pested.osu.edu/wdilicense.html Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
In FL you can't even call it an ant unless you are "qualified". That actually works in the inspector's favor. Just say it is an insect and I think you will CYA. Then it is time for the bug smashers to come and determine the pedigree and genus.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Its been my experience that if ants are in the attic...they are also somewhere else within the home and have branched off into the attic.
JMO John R Fordyce Safe-Buy Home Inspection Keystone Inspection & Testing Services NACHI #06051992 Safe-Buy Home Inspection Keystone Inspection & Testing Services << Home Inspector Marketing Map - Marketing Madness for Home Inspectors >> |
I have found that sometimes ants fall from low trees that either overhang or touch the roof and enter through attic vents.
"Ants in the Attic"
What kind of music to they play? CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
"What kind of music to they play?" - Adam Ant's of course ( for those of us who remember the 80's)
Also check to see if power lines (if above ground) are going through a tree. Ants love a nice electrifying walk in the late afternoon.
Cincinnati Ohio |
Water and ants, ants and water note it reccomend an exterminator and ELIMINATION OF THE MOISTURE CONDITION. The second half of that was your job the first half was not. If those are carpenter ants they are unlike any species I have previously seen as the tail end of the abdomen is very pointy. The advice to take a sample to an entomologist is good but it ain't your job.
| Roof decking condensation. | Homewood | Interior Inspections | 15 | 3/5/10 11:00 AM |
| Mold question? | ccurrins | Interior Inspections | 35 | 1/23/09 11:55 AM |
