rgrizzle is a non-member guest and is in no way affiliated with InterNACHI or its members.
What could cause the discoloration on the wall coming from the outlet? I think it is water coming from the roof down the wall and entering the outlet and now the outlet componets are rusting.
Any suggestion or different thoughts. |
Michael Merino is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would agree, Also, I think I see 2 round areas of discoloration from moisture where I assume the drywall nails would be . |
yep that is the drywall nails starting to pop. I just wanted some suggestions on this before I wrote it up.
Well, I am not a HI yet. So do not rely on me. I am in training.
Is that a humidifier right next to it? Or a dehumidifier? It does appear to be moisture related, especially if the box is starting to rust.
Or is that unit a space heater? Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network INACHI Awards Portal Want To Exchange Links? What we've got here is......failure......to communicate.....
A heater. OK. Is there a window close to that outlet?
yes there is here is a pic from outside and on inside, there is a window a/c in the widow next to this wall.
Don't forget the chance of the HVAC condensate from the air-conditioner. Leaving the window open for the air-conditioner and is probably the source though!
oh, take a look at this one. same house.
Kind of makes you laugh. You see all the "ventilation" around the A/C and right next to it is the space heater. Wonder if they were using both. Probably not, but funny pics when you consider them together.
I got alot of good pics from this job. Some of them make you say what where they thinking?
Did you get a chance to check the attic space in that area??? or the roof for a vent that the flashing may have gone bad and leaking from that area. How was the framing around the a/c unit, was there any weather stripping or anytype of securement for water intrusion..
Missouri Home Energy Auditing Services Residential & Commercial Inspections Serving Central Missouri Certified Missouri Home Inspector InterNachi ID # 07110204 Environmental Inspection Solutions & Services Thermal Infrared Imaging-Certified Thermographer Energy Audit Consultant/Survey-Inspector CMC Home Tune-uP Certified ID # 1505 E.S.A. Certified Mold Inspector & Assessor CMI CMIA |
| Web Site Building Software Looking for suggestions | ecrofutt | Inspection Hardware, Software & Publications | 6 | 9/5/06 9:58 AM |
| HELP-pre-listing inspections suggestions?? | mschild | Miscellaneous Discussion for Inspectors | 27 | 4/23/06 2:35 AM |
