Old 6/29/11, 3:33 PM
Phillip Craddock Phillip Craddock is offline
Default Anything special to look for?
Inspecting 1960's home tomorrow, anything tricky I should look for?
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/29/11, 3:36 PM
Joe Funderburk, CMI's Avatar
Default Re: Anything special to look for?
Aluminum wiring.
Cast iron and galvanized plumbing.
Decay beneath bathrooms and kitchen sub-floors.
The list is too long to type up. Practically any defect could be present.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/29/11, 3:38 PM
Roy D. Cooke, Sr's Avatar
Look for Vermiculite in attic it could have asbestos,
Floor tiles 9 inch any I have seen have asbestos in them .
Cement asbestos siding .
Old 6/29/11, 3:43 PM
Jeffrey R. Jonas's Avatar
In my area, first two things that jump out at me...
Solid aluminum conducters
Vermiculite insulation
Next would be...
Electric in-floor heat
Galvanized water supply pipes
Old 6/29/11, 4:50 PM
Expect double tapped neutrals. No separation of grounded and ungrounded conductors at distribution panels.
Did I already say galvanized pipes???
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/29/11, 9:39 PM
Sean Fogarty's Avatar
Another poorly maintained home. How exciting!!!!
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 7/4/11, 3:04 PM
Justin Roberts's Avatar
Justin Roberts Justin Roberts is offline
Joe, how do you report on these. I see it quit often when the neutrals are double tapped and even the ground is on the the same screw as the neutral on the buss bar.
Justin Roberts
Roberts Property Inspections
PO Box 1972
Big Bear City, CA 92314
(909) 618-4697
BigBearHomeInspections.com
Old 7/4/11, 11:33 PM
This is how I do it.
Double Tap:
One or more neutral wires are incorrectly connected under a single screw on the grounding or neutral bus bar at the *IDENTIFY(electric/panel)*, and should be serviced. While this is a common defect and a technical wiring violation, unless the manufacturer states otherwise, bus bars are only designed for one current carrying conductor per terminating screw.
Sub-panel bonding issue:
The sub-panel(s) had neutrals and grounding conductors tied to the same bus bar. Sub-panels are required to have a floating neutral bus and a bonded ground bus. Separation of grounds and neutrals is required to achieve this. An evaluation by a licensed electrician is recommended.
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/4/11, 11:47 PM
James H. Bushart's Avatar
Look at everything. Describe what you see.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 7/5/11, 11:56 PM
Double Tap:
Thanks Joe that helps.
Justin Roberts
PO Box 1972
(909) 618-4697
Old 7/6/11, 1:27 AM
Joseph Hagarty,  CMI's Avatar
1960?
that is a new home here on the Main Line, PA....
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
New Special for April on IR Camera and Class jmckenna1 Thermal Imaging, Infrared Cameras & Energy Audits 0 4/2/11 3:30 AM
Chicago Special Education Event rmyers1 General Inspection Discussion 0 3/19/06 11:41 PM
