View Poll Results: Do you inspect (ie test) appliances?
Yes 28 82.35%
No 6 17.65%
Voters: 34. You may not vote on this poll
Old 6/9/11, 6:50 PM
Default Appliance Inspection
According to our SOP we are not required to inspect appliances. Do you?
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/9/11, 7:28 PM
Bob Elliott's Avatar
Default Re: Appliance Inspection
Pretty much all the time unless they are c-ap and the buyer is telling me they will replace them.
Question for you guys that do not know how or do not feel like it.
Do you at least check connections to the appliances such as vents and waterlines,gas lines,etc.?
Say you do not and there is a gas leak do you figure not your problem?
Old 6/9/11, 7:58 PM
Greg Keene, CPI's Avatar
Greg Keene, CPI Greg Keene, CPI is offline
Test all appliances - run dishwasher, turn on stove burners, turn oven to 400 and check temp after preheat, run microwave and check for leaks. Clients are impressed with testing. Tested an oven set at 400 and when preheat done, showed a temp of 488 degrees. Tenants buying house and wife said, "See I didn't burn the roast, it was the oven!". then winked at me and said "Thanks".
Greg Keene
Clear Choice Home Inspections
Evergreen, CO
303-674-3234
greg@clearchoice-hi.com
Old 6/9/11, 11:33 PM
Yep may not be in the SOP but has anyone noticed Nick hands out Microwave testers at Christmas.?
Old 6/10/11, 9:51 AM
Patrick Carter's Avatar
Patrick Carter Patrick Carter is offline
only the built-ins...
Patrick Carter
BPI Certified Professional Building Analyst
Missouri Certified Energy Auditor
Kansas Certified Energy Auditor
Call (816) 510-3234
Old 6/10/11, 10:15 AM
??? Care to explain that one ???
Old 6/10/11, 12:45 PM
rramsey1 rramsey1 is offline
Please Note: rramsey1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Part of Standards in Texas
Old 6/10/11, 1:25 PM
David A. Andersen's Avatar
Hay, where is your sign? (from a Texan)
This guy is from Cnanada!
BPI# 5015804
Old 6/10/11, 3:10 PM
George E. Russell George E. Russell is offline
Ralph beat me to it. It IS part of OUR SOP
George Russell
George Russell Professional Inspections
Austin,Texas
TREC # 10215
512-296-9538
http://georgerussellprofessionalinspections.com/
http://www.facebook.com/austinhomeinspections
Old 6/10/11, 3:13 PM
James H. Bushart's Avatar
Nope.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 6/10/11, 7:25 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Yes I do unless the client specifically tells me a certain appliance is being replaced, otherwise Yes I test them all.
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 6/10/11, 10:14 PM
David Garton's Avatar
David Garton David Garton is offline
I test all appliances, IMO it is part of a complete home inspection, at least for my inspections
David Garton
Eagle Eye Inspection Services
david@yubacityhomeinspection.com
http://yubacityhomeinspection.com
Licensed Building Contractor
Serving Yuba City, CA. and the surrounding areas
(530) 415-1269
Old 6/10/11, 10:27 PM
Chuck Evans's Avatar
All appliances that are part of the transaction.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 6/11/11, 1:08 PM
Built-ins only. If they are free-standing, such as refridgerators, freezers, counter-type microwaves, washers, dryers, they are not checked by me. These units you can never tell if they are staying with the property or not. Mostly all dishwashers, stoves, wall units, permanatly attached microwaves, HVAC, etc.
Yes, and no to the question above.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 6/12/11, 3:48 PM
Charles L. Harper's Avatar
Charles L. Harper Charles L. Harper is offline
Same here, I test built in microwaves, dishwashers and stoves and cooktops. No refrigerators or washers or dryers.
Charlie
www.HomeInspectionGA.com
McDonough, GA.
770-722-3717
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
Space At Units sparks Inspecting HVAC Systems 5 1/8/07 1:57 PM
Another reason to recommend CO testers rnewman1 Interior Inspections 2 10/12/06 7:47 AM
