I Had a client ask me if these were asbestos ceiling tiles or not. This is in a 50's block style commercial building. It does have a suspended ceiling below it. I dont test for Asbestos, (and told him so) but wondered if anyone else would have a quick answer.
If not, where could I recommend he have one tested? They look like paperboard to me. |
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
A small sample to a good lab. Last one I did, 35 bucks.
Duke Griffin EcoVision LLC Home Inspections in Estes Park, CO |
What Lab was that Duke? Prolab?
Yup. Just took a small sample, into a zip lock bag, off to Pro_lab and shazzam, no asbestos.
Read earlier today that if it is before 1980 and is white or grey at the center it is most likely asbestos but brown it is not.
No idea of accuracy. |
Remove Asbestos Ceiling Tiles
Asbestos ceiling tiles were commonly used in homes and buildings before the 1970s. Asbestos is a fiber that was once used in "acoustic" ceilings which were also called "drop" or "suspended" ceilings. Before the carcinogenic affects of asbestos were known; many people were unfortunately exposed to these fibers since they were often used in numerous different materials including*roofing*and ceiling products. Asbestos is only dangerous if the material is airborne; therefore, contaminated ceiling tiles are only harmful if damaged. If you would like to remove these tiles from your ceiling, it is best to have a licensed*contractor*complete the*job*for you. If you decide to remove the tiles yourself, you will need to proceed with extreme care and caution. Difficulty:*Moderate things you'll need: Asbestos Ceiling Tiles Tyvek Suit Safety Glasses 6 mil polyethylene bag Yellow Bags for Asbestos Duct Tape HEPA Vacuum Approved Respirator HEPA Filters Water with Detergent Spray Bottle Tarp Ladder |
The adhesive (the round globs) usually comtained asbestos too. Take a separate sample of that too.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
In the 50's I think the questions should be "What doesn't contain asbestos."
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
| How do you report Asbestos Floor Tile ? | belliott | Interior Inspections | 25 | 11/15/09 10:01 PM |
| Help! Asbestos Pipe Insulation | John Doem | General Inspection Discussion | 24 | 6/3/08 9:59 AM |
| Asbestos | jlybolt | Exterior Inspections | 41 | 7/17/07 1:13 AM |
| Asbestos question... | gromicko | Ancillary Inspection Services & Additional Topics | 6 | 1/9/06 1:03 AM |
