Old 8/25/08, 9:49 PM
wlord wlord is offline
Default Asked to Change Report
I recently did an inspection for a friend of my brother. The house was built in the early 1970's and had some very mature trees and shrubs very close around it. It had a new gable roof built over an old hip roof with the HVAC ducts run between the two roofs. The roof appeared to be in fairly good condition except for an improperly flashed area and a need for a roof drainage system. It had no gutters. I crawled the attic and found no evidence of water intrusion. A tree about 12-15" in diameter had been cut down that was growing within a foot of the foundation. The foundation was a crawlspace with cement block underpinning. There were a couple of very large trees growing close to the house.
In my report I noted all of the items mentioned above with pictures and the suggestion that the foundation be further evaluated because of the possibility of damage from roots. There was no redily visible damage.
My problem is this: my brother told me his friend was going to lowball his offer and wanted me to change my report to say that there was foundation damage and that it needed a new roof. I refused and stated clearly that I stood by my inspection report as-is. My integrity is not for sale. I would like to hear other opinions. What would you do?
Old 8/25/08, 9:53 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Re: Asked to Change Report
I would not change my report.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 8/25/08, 9:55 PM
Erol Kartal Erol Kartal is offline
Please Note: Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
William,
Why in the world would you jeopardize the livelihood of your family for a home inspection? Think about it.
Old 8/25/08, 9:58 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
You did the right thing. I will not change a report for anyone. I don't know that I would have called for evaluation on the foundation with no damage visible, but if that was your decision you should stick with it. I was not there and didn't see what you saw. Anyway, back to your original question. Absolutely, under no circumstances do I change my report because someone wants me to. I do review my reports and if I found I have made a mistake I will issue an addendum to my report. If a customer calls and thinks I am wrong I will check into it, and occasionally, if I feel I worded something wrong, I will make a change. But, no, I would not alter a report just so your client can lowball the offer. I am sure you could get yourself into some trouble for doing this. So stick to your guns on this. You did the right thing.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 8/25/08, 9:59 PM
I wouldn't jeopardize a thing. As I told my brother, my integrity isn't for sale. I was just wanting other people's opinions. Thanks for the reply!
Old 8/25/08, 10:01 PM
mnahrgang's Avatar
You are being hired to report on the condition of the home. Not to make stuff up so the buyer can stick it to the seller. Not ethical in any book. You made the right call.
Mark Nahrgang
www.HeyMark.info
Old 8/25/08, 10:12 PM
Oh, Lord, don't change your report!
That's called fraud, no?
Larry Kage, CMI
231 929 3525
Old 8/26/08, 12:18 AM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
Nuff Said!
Bye the way.... I would have a talk with my brother about his even having the nerve / gall to relay this message to you!
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Old 8/26/08, 1:00 AM
William R. DeVries, CMHI's Avatar
William R. DeVries, CMHI William R. DeVries, CMHI is offline
I also agree do not change anything, I'd also go one step farther and give him his money back and tell him to find another inspector, then I'd tell your brother to loose your phone number.
Loose the both of them and walk away, your a better man and this ***** can never be explained away, its worse than luggage that you can't toss out.
I wish you the best in this
ASNT Certified Level II Thermographer
Certified Mold Inspector (Pro-Lab)
Certified Mold Inspector IAC2
Certified Home Inspector INACHI 07040201
Commercial Property Inspection
Certified Master Home Inspector
2008 InterNACHI member of the year
Magnum Property Inspection
Inspect it before you buy it
613 813 2353 mobile
We use and recommend
Home Inspector Pro Software
HomeGauge Software
Old 8/26/08, 2:20 AM
mreusch mreusch is offline
Send a message via Yahoo to mreusch
If I may ask? What profession is your brother in?
Old 8/26/08, 2:22 AM
Dale Duffy's Avatar
Ditto
Old 8/26/08, 4:02 AM
Barry Adair's Avatar
WDL,
Is changing brothers an option?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 8/26/08, 9:19 AM
Barry
Im not sure on changing but I do know cuttings siblings loose is a possibility, As a really good friend of mine says to me, loose the toxic people in your life they are not needed.
And I agree with that, who needs it or wants it.
613 813 2353 mobile
HomeGauge Software
Old 8/26/08, 5:58 PM
Ben L. Garrison Ben L. Garrison is offline
I think it could be that the brother was the messenger in all of this, not the person requesting the change in the report? Losing a sibling for passing along the intentions of a friend is a bit extreme. I would simply tell my brother to tell his friend to go F himself and be done with it.
Old 8/26/08, 6:33 PM
George P. Wells, CMI's Avatar
.I refused and stated clearly that I stood by my inspection report as-is. My integrity is not for sale. I would like to hear other opinions. What would you do?
No. I've been asked to change reports a few times. I won't do it. It is not up for discussion.
BestInspectors.Net
Windows - iOS - Mac - Android
Continuing Education
http://www.bestinspectors.net
est. 1992
Need to know???? cbottger Canadian Inspectors 1279 4/30/10 5:31 PM
Roy the proof you asked for wdevries Canadian Inspectors 55 7/8/08 10:30 AM
Verbal home inspection report sparks complaint rcooke Canadian Inspectors 16 8/21/07 11:12 PM
New Report Upload Technology cdemsky Miscellaneous Discussion for Inspectors 49 5/1/07 10:19 AM
