| Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America) |
perimrter curb????
Changed to
"The living space is separated from the garage by a firewall that extends from the floor to the roof. If the ceiling material is fire-rated, the firewall can terminate at the ceiling" Thank you Researcher and Technical Writer, InterNACHI |
Hi. Michael, hope you are doing well. I thoght it was one of the same. Firewall- a wall constructed to prevent the spread of fire Separation Wall- a wall compartmentalizing an area from another to contain smoke or fire. Garage firewall / separation wall - The whole idea is to give you an extra hour of protection (separation wall between the garage and the house is currently required to provide one hour of fire resistance) from the fire that might start inside the garage. In order to achieve this rating, the wall needs to be sheathed with at least 5/8″ drywall on each side (from the garage and home side), but check with your local code enforcement division … some jurisdictions will double that thickness. The separation wall should have no missing / damaged drywall sections, any penetration must be sealed (fire rated caulking would be perfect for small gaps around the pipes, air ducts, door frames, etc). If the wall is made out of brick, cinder block, stone, solid concrete, or any other non-flammable material, you’d just have to worry about penetrations. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
My own house does not have one, but that was before some of those codes were required. The new houses that I have seen without the step-up to living space, usually have a sloping floor to the exterior as you say Brian. The ones with floor drains require an oil water separator before exiting to the city or positive outfall. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Perhaps you would like sharing a code reference on the required step?? Even with a curb stop/step a sloping floor has been a requirement for some time. |
Marcel, the argument in the past has been that a true fire wall was a rated assembly meeting what, ASTM or NFPA requirements, and that a separation wall was much less strict. I don't have the inclination to get into a debate about it ( I don't mean that to be ugly or anything, it's just not that important an issue to me) but there was a good thread on this a year or so ago. I think it may have been Joe Farsetta that was bringing the topic up. I'll try to find the old thread.
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
I haven't had this many complaints since the old days. Keep knockin me down, it builds the articles up! Researcher and Technical Writer, InterNACHI |
These aren't complaints Rob...just constructive criticism.
Thanks Brian, I remember that discussion also. Forget if we all agreed on something or not. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I don't think we did....has that ever occurred on anything?
Would be nice if it did Michael
Exactly Rob, for the most part your articles are pretty good right out of the shoot.
| New article on garage doors and openers | inxil | InterNACHI & RealMatcher Blogs | 0 | 7/10/09 11:20 AM |
| Inspecting Garage Doors and Openers. Please proof this new article. | gromicko | General Inspection Discussion | 10 | 7/1/09 3:53 PM |
