Can any one tell me where, if any,a code that address attic doors to dwelling. Do they need to be fire rated? I found a hollow core wood door with rubber weather strip.
I recommend installing 5/8" drywall over every existing wood access door. Replace wood frame that holds door in place with dywall frame. No code reference, common sense safety issue. Stan
Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 |
The wood frame burns away. The access door falls to the garage floor, leaving a big hole for fire to enter the attic.
Using your logic do you also reccommend replacing the wood garage entry door frames to the living space with drywall? Seems like fire taping or fire caulking before wood trim placement would accomplish what you are attempting to do with drywall. May even look nicer. hth ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Thanks..... I have not laughed so hard in a long, long time! If you were really serious about the "burning frame" falling to the floor you would have recommended a steel / metal door and framework! In another comment {if I read you correctly} you recommend "closing / eliminating ALL attic access doors" I asked what about the ones that come "Pre Manufactured" and are in the bedrooms or upstairs hallways? Do you have an answer for that question? Now.... really.... what is your reasoning behind all of this? PS: If you are just "Joking / Kidding around" please let me know so that I can move on to other things. Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 Last edited by fcarrio; 8/16/08 at 6:03 PM.. |
If you want a fire rated attic access door, install one of these: http://www.rainbowatticstair.com/att...re-ladder.cfm# He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
I didn't make myself clear. I was talking garage ceilings only. If the attic access door is wood I recommend it be covered with 5/8" drywall. Most of the trim that holds the door in place around here is wood trim used around interior doorways. Replace that with drywall and eliminate all exposed wood. You look up and see no wood. I'm glad I made you laugh. It is good for the soul. I will choose my words more carefully next time. Stan
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
If it's hot enought to burn the trim off the ceiling access hatch, you're screwed anyhow. JMO |
Here is the substitute, but doubt we will see those on our inspections.
http://www.batticdoor.com/atticaccessdoor.html THE EZ HATCH ATTIC ACCESS DOOR FOR NEW AND RETRO-FIT CONSTRUCTION INSTALLS IN MINUTES INTO A 22-1/2" x 30-1/2" ROUGH OPENING!! Last Inspection did not have a hatch.
Previous was nailed shut. Previous to that was plywood. I'm lucky to find one that is 22"x22". Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
Wow. I'm recommending further fire protection at the wood access door on the garage ceiling, that's a good idea isn't it? It eliminates all exposed wood. If you find that odd that is OK with me. That is your opinion. No need to get personal guys. You don't know me, you have no idea of what type of inspector I am. Stop the hatred. I've been viewing this message board for 4 years now and it is a great source of information. Your replies should not surprise me. And yes I am licensed and will be renewing in November. I did my pre licensing through the Midwest Inspectors Institute (Thomas Lauhon) and it was very very informative. Licensing gives you credit in the eyes of the client and that in turn gets you inspections. You guys have a nice week. Stan
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| Attic Access to HVAC equipment | kweiss | Inspecting HVAC Systems | 15 | 9/13/07 10:19 AM |
| Open attic access from garage | jveivia | Interior Inspections | 13 | 7/26/06 1:01 PM |
