Old 3/6/10, 8:28 AM
Roger K. Ormiston Roger K. Ormiston is offline
Default Attic ladder in garage
Having a drop down attic ladder an attached garage obviously compromises the firewall requirements. Is there a work-around, or should we write up all of them?
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/6/10, 8:37 AM
Default Re: Attic ladder in garage
Does it still have only the thin plywood? If so, that is a problem. It needs the fire rated drywall or equivalent in all areas of the fire separation wall/ceiling.
Larry Kage, CMI
231 929 3525
Old 3/6/10, 11:34 AM
Jeffrey R. Pope's Avatar
There are ladders designed for use in firewall systems, and there are ways to modify others to meet the necessary requirements.
If it is not rated for installation in the firewall, it should be reported as such.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/6/10, 11:57 AM
Yeah, I've found two in the past week with just thin plywood, so those obviously get reported. It occurs to me that even if it is fire-rated - if it doesn't seal completely the fire wall would be compromised, so I've basically started writing them all up. I never see one that seals properly.
Old 3/6/10, 8:30 PM
Brian E. Kelly's Avatar
http://www.atticladdersplus.com/prod...categoryID=545
Old 3/7/10, 7:44 PM
Rick Sovastion's Avatar
Rick Sovastion Rick Sovastion is offline
Check this out.
http://www.precisionladders.com/
Rick Sovastion
Advanced Home Inspections
1711 Grafton Road
Morgantown, WV. 26508
304-291-8282
Go WVU Mountaineers
Old 3/7/10, 10:52 PM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
see'em all the time around here....write it up..
Old 3/8/10, 12:44 AM
Joe Funderburk, CMI's Avatar
Around here, you can modify a drop down stair to make it compliant with building fire codes.
http://www.aohomeinspection.com/pdf/Firewalls.pdf
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
Old 3/8/10, 9:48 AM
Barry Adair's Avatar
please provide manufacturer approved testing data to back up this prescriptive retrofit...the plaintiff's atty. will request this...
i'll stick to identifying the issues and leave the repair/replacement prescription to others...
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 3/8/10, 10:41 AM
Wayne B. Wilson's Avatar
Well around here you can use a Paint and Fire Retardant Coatings
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 3/8/10, 10:56 AM
I don't understand Barry and Wayne's reply. If the AHJ is OK with it, why shouldn't that be OK with a home inspector and why should a home inspector be afraid to furnish the AHJ's document? The buyer can do whatever he wants. By the way, I've NEVER seen one compliant or modified in a garage.
Why would anyone be concerned about the manufacturer's testing data? That's taking it too far IMO.
Finally, do I need to be concerned about "testing data" when a homeowner removes the string and installs an I-bolt to pull the stairs down?
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/8/10, 11:46 AM
I am not concern with it Joe just saying they will accept it. But i was talking to a builder he has the same can of paint for several homes just leaves so the inspector looks at it. He really does that . can has gone through many homes . So i still mention the rating .
Wayne Wilson
865-256-1490
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 7:31 AM
Ladder Safety Extensions mcyr Miscellaneous Discussion for Inspectors 3 4/6/09 11:10 AM
Ladder Safety from ITA badair General Inspection Discussion 4 8/9/06 7:59 PM
Ladder safety by Rick Bunzel gbeaumont Miscellaneous Discussion for Inspectors 9 3/24/06 6:24 PM
