Old 10/2/11, 2:27 PM
Robert J. Huska Robert J. Huska is offline
Default Attic space ventilation
I'd like some advice on an inspection in regard to ventilation in an attic space where most of the 2nd floor is finished....2 BR, 2 BA....finished. There are about 6 unfinished storage areas behind kneewalls on both sides of the 2nd floor. There is also unfinished attic space above the finished ceiling. What I think may have been done is the original roof vented the attic space with a power vent because I saw pieces of one laying in the insulation. They just put a new roof on the home and installed a ridge vent. There is vented soffit, but it is completely separated from the space that is vented by the ridge vent. Is a ridge vent effective without the aid of vented soffit? Now, the only means of venting the 6 storage areas behind the kneewalls is the vented soffit, and the homeowner has insulation stuffed between each rafter. I'm not sure what to recommend beyond removing the insulation stuffed between the rafters to allow some means of ventilation to the storage areas. Sorry for the long explanation.
attic-space-ventilation-mcintyre-254-reynolds-mill-road-york-17403-077.jpg   attic-space-ventilation-mcintyre-254-reynolds-mill-road-york-17403-080.jpg   attic-space-ventilation-mcintyre-254-reynolds-mill-road-york-17403-084.jpg   attic-space-ventilation-mcintyre-254-reynolds-mill-road-york-17403-094.jpg
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/2/11, 2:48 PM
Christopher Currins's Avatar
Default Re: Attic space ventilation
Remove insulation from adequate number of vented soffits. Install drywall, or baffles, at trusses. "Open" top of kneewall to allow intake air from soffit vents to exit at ridge vent.
Christopher Currins
Certified, Licensed
Old 10/2/11, 5:11 PM
Kevin M. Leonard's Avatar
Kevin M. Leonard Kevin M. Leonard is offline
What Chris said only I call them rafter vents. http://roofing.owenscorning.com/home...raftrmate.aspx
Kevin M. Leonard
The Ohio Home Inspections Company
513-895-7700
937-283-5118
Old 10/2/11, 5:14 PM
http://www.youtube.com/watch?v=Hbv45I_qs4U
Kevin M. Leonard
513-895-7700
937-283-5118
Old 10/2/11, 8:29 PM
David A. Andersen's Avatar
Did we not already discuss this Robert?
Read about ridge vents. They require upper and lower vents to operate. Period.
As a matter of fact you can go look up some building code and find that there is a ration requirement between upper and lower vents.
The law of fluid dynamics states that for a fluid to move from one area to another there must be:
#1 A pressure difference.
#2 An opening for the fluid to pass through.
If you let air out the top of the roof you must replace that air.
If the air is rising because it is hot, the pressure is higher at the top, lesser at the bottom.
Where should the other vents be located?
BPI# 5015804
Old 10/3/11, 9:41 AM
Jeffrey R. Jonas's Avatar
Maybe he just couldn't find the thread again... http://www.nachi.org/forum/f2/attic-...venting-64846/
Old 10/3/11, 5:39 PM
Anthony F. Miceli Anthony F. Miceli is offline
Yes, I couldn't agree more with everyone's opinion. Some people think stuffing the soffit vents with insulation is keeping the house warmer, not knowing they are creating more moisture to sit in the attic causing mold and wood rot.
Information regarding condensation/ attic foam insulation and ventilation, corellana Interior Inspections 6 8/3/11 9:00 PM
Roof decking condensation. Homewood Interior Inspections 15 3/5/10 11:00 AM
Crawl Space Ventilation rfrost Interior Inspections 2 5/16/09 7:54 AM
Is inadequate roof or attic ventilation a defect? gliebig Exterior Inspections 85 1/16/08 6:56 PM
