Just a curiousity question. Anything particular/different/specific involved in a horse barn inspection? Apparently a huge barn with inside riding track, hydro and plumbing, no insulation and open rafter steel roof . Ontario, Canada
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You need to watch where you step.
is it timber construction, steel check all joints and bracing, bring binocs and look at trussing, if steel bring spud wrench and test bolts, if wood inspect dowels and collar ties, purlins, inspect soffits, ensure ridge vent is clear and working, check walls and how fastened to slab, bring shovel to inspect depth of slab, look for partial gutter at entrances and downspouts with extenders, look where hay is stored ( fire hazard) utility room, tack room, chemicals locked up, look for bait boxes and accesability to pets and kids. horses require approx 100 sqft minimum each check for over crowding and feed storage in safe dry place so mould is not enhanced.
thats what comes to mind this minute good luck, there an animal all their own, barns require a keen eye and an understanding on how they are operated and proper function.. ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
Two questions:
Is this barn in a northern climate where it snows? Are the new buyers going to use it for the same purpose the existing owners use the barn? Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
The biggest problem I see with barns is that the new owner buys a working farm or farmette, but then doesn't keep cows (they just want the barn).
Once you take the animals out of a barn, the foundation often begins to suffer from freeze/thaw. The animals keep the barn warm. Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
also look for kick damage, manure piles to close to barn, look at the tack room closely ,there should be water & electric at least here there is , like Bill said usual timber frame construction
Dennis R.Goudreau D.R.G. Inspections LLC www.newhampshirehomeinspector.biz www.nhinfraredthermalinspections.com http://co.nachi.org/inachiawards |
Apparently the barn has not been used for several years. Some strange deal that fell through and owners were renting to someone, so the agent is not getting any help as to the background/history of the place, yadda yadda...The place is located in Ontario, Canada, so there are cold months with snow. I have only spoken with an agent so dont know anything about the place or what the buyers plan to do with it, yet. Thank you's for your advice.
I would start with the foundation. Stone, rubble, wooden, block, etc. Then the timbers. You have to have a knowledge of barn framing. Post-and beam is typical and here is a link. http://www.barntoolbox.com/post-and-beam-barns.htm You will see wood jointing of various techniques. Then the roofing and exterior shell or envelope. The electrical can be 3 phase and plumbing is often simple unless for cattle. Milking. So no it is not simple and it is dependent upon what that barn was used for. I hope that helped. Thanks...Robert |
Nick makes a good point. I just saw a thing where the Mall of America has no heaters. They use the sun and the people to heat the building. A person puts out around 600 BTU per hour. So the animals have to produce allot more.
One house had an article about it in a 1986 edition of Fine Homebuilding. The 1.5 storey home (2,500 sq ft + finished full basement) was finished just before Xmas that year. The owner had a small family re-union over the holidays on a dull, sunless day that outdoor temps were -10*C (14*F). With the stove on cooking food for about 30 people + the body heat, the house started overheating....they turned the air exchanger to high to try to get heat out and cooler air in but eventually had to open windows! I personally blew all the cellulose insulation for walls (R32) and attics (R60) of that home. PS: BTW, he went to work in southern NH for about 17-18 years and now has returned back to New Brunswick to renovate the 130+ year old family farmhouse that he inherited into to a near "zero energy" retirement home. Last edited by Brian A. MacNeish; 1/30/11 at 7:18 PM.. |
Brian
Can you get your hands on any literature or drawings Brian of his system? I would like to take a look. Make a good read. |
http://books.google.ca/books?id=1IqB...hanger&f=false PS: Here's one very similar to what he made but used wood for the frame and heavy plastic for the plates: http://www.ehow.com/way_5810256_home...exchanger.html Another: http://makeprojects.com/Project/Heat-Exchanger/279/1 Last edited by Brian A. MacNeish; 1/30/11 at 7:40 PM.. |
No not for heat exchangers. I have looked at them at building products stores Brian.
I meant your friend drawing of his system ( John Amos (artist and imaginative builder) put together a framing/ insulating system he called the "balloon framed trusswall" ) |
Can't find anything easy online, I have the issue stored in boxes.......somewhere.....!~!~ Here's the info about the Fine Homebuilding article: The Balloon-Truss SystemJohn Amos Issue 24 December/January1984/1985 Page 65 Maybe someone has an easily retreivable copy. Here's something similar. In his, the trusses went into the earth (bottom ends were appropriately treated foundation wood stock) to become a PWF (permanent wood foundation)!! http://www.greenhomebuilding.com/art...arsentruss.htm |
Thanks Brian. Dam nice of you.
Thanks...Robert. |
| Barn Door Fan | sharris | Miscellaneous Discussion for Inspectors | 10 | 2/11/09 7:24 PM |
