Old 9/24/08, 7:46 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default Big holes!
Found these I-Joists today (two story townhomes) with holes cut to route HVAC ducts cables, etc. They were at the center of the span but seemed to be excessive. All the holes were so uniform (all the adjacent units were the same) they looked like the were made that way. What do y'all think?
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 9/24/08, 8:00 PM
tdietrich1's Avatar
Default Re: Big holes!
Oh absolutly beautuful.
I've seen HVAC guys eat up I-Joists but this is the worst. Mind if I use the photos?
Tom
Old 9/24/08, 8:14 PM
Help yourself
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 9/24/08, 8:24 PM
Jeffrey R. Jonas's Avatar
Robert,
This info from LP...
http://www.lpcorp.com/Literature/LP_...e_Overview.pdf
Scroll down to page 5.
Maybe it will help
Jeff
Old 9/24/08, 8:43 PM
Thanks Jeff. Here's a link to the mfg of the I-joist in my pix http://ilevel.com/literature/TJ-4000.pdf
Note under General Notes it states to leave a min of 1/8" web above and below the hole. Am I reading that right????
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 9/24/08, 8:47 PM
Barry Adair's Avatar
Yeppers!
Holes may be located vertically anywhere within the web.
Leave 18" of web (minimum) at top and bottom of hole.
Someone's gonna need a letter stating repair method or replacement
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/24/08, 10:08 PM
rshuey rshuey is offline
Please Note: rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
They are made that way.
Old 9/24/08, 10:34 PM
Can you give us a little more information?
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 9/25/08, 9:33 AM
certainly. Every major manufacturer of engineered wood floor joists will and can put cutouts for electrical, HVAC, plumbing, etc. the holes can be as large as shown in your pics. you need a minimum of 1/8" webbing to maintain minimum structure standards.
To put it in an easy to understand format. the cutout circle is kind of like an egg. if you place an egg in your hand and compress top to bottom, it will not break. Same science applies here. The top and bottom plates along with the perfect circle (or sometimes a triangle) will hold all weight needed.
New Construction & No Weep Holes jfunderburk Exterior Inspections 38 5/26/11 12:28 PM
Brick house nbhi Exterior Inspections 28 2/17/08 4:22 PM
Question about weep holes. gromicko Exterior Inspections 10 1/28/08 11:25 AM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 10:20 AM
Sink Holes May 13th zfackler General Inspection Discussion 0 5/2/06 12:01 PM
