What is an electrical distribution wire to a breaker that would be either black or brown and is BRAIDED fabric?
| Find an InterNACHI certified Iowa Home Inspector (and anywhere else in North America) |
It looks like old cloth covered wire. The sheathing surrounding the conductors can be brittle and may crumble away, if the wiring is moved around much, and could lead to a short.
Hard to tell, but it could also be aluminum wire
Common in older homes.
http://www.inspect-ny.com/aluminum/recogniz.htm
http://www.alwirerepair.com/examples_of_aluminum_wiring.htm InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
It's not aluminum, it's tinned-copper - cloth covered, tinned-copper.
It could never be aluminum. Copper or tinned copper only, aluminum wasn't used until the late 60's. "By three methods we may learn wisdom: First, by reflection, which is noblest; Second, by imitation, which is easiest; and third by experience, which is the bitterest." -Confucius Certified Master Inspector (2007) Member, International Assoc of Certified Home Inspectors (InterNACHI) Member, International Code Council (ICC) - Certified Residential Combination Inspector Square-One Inspection "Assurance begins here"
My previous post #5 http://www.nachi.org/forum/f11/braid...62/#post517392 will help people identify and recognize aluminum wiring, if desired.
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 10:24 AM |
| Handbook for Electrical Safety | pabernathy | Electrical Inspections | 1 | 1/1/07 2:14 PM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 2:48 AM |
