I dont think I have encountered this before. A chimney with no flue liner, only a short clay liner out the top. The brick is in bad shape, with cracked mortar and even loose brick. Triple chimney, 1 for furnace, the other 2 for wood burning fireplaces. Customer is concerned he may have to replace the entire chimney. Is is possible/recommended to repair the brick, and line chimney?
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
See them all the time here. Yes a liner is needed. And yes, corrective action is in order. What needs to be done? You know the drill..... Report it & let the chimney professional determine corrective options.
Yup, what Josh said..
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
I agree with Joshua, we have them here all the time . seen them with out mortar left .
Liners are available. but should be checked for support and so on. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
I seen plenty like that. Usually in old homes.
Not good. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
This was a 1974 ish home. Was this a "lets do it quickly and get done today" practice, or was this just common practice of the day?
I do intend to call it out, just a first for me. |
Lets do it quickly i would say . Mostly found on homes 50's and later here. they should have known better in the 70's Perhaps the builder was toking lol
With adequate repairs and a liner, a fireplace insert may be more possible. Qualified professionals will have additional options. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
The way it's repaired is that they put an inflatable sausage-shaped tube down the chimney and then pump grout around it, which fills in all the holes you describe.
Now why does that sound so dirty lolol
Mortar may be okay. Recommend a Level II inspection. repair can be as Nick described with pumped concrete or a steel liner )depending on configuration). If the chimney is structurally sound, a liner would do the trick. 'Round these parts, around $5k or so.
[quote=mroberson;784783]I dont think I have encountered this before. A chimney with no flue liner, only a short clay liner out the top. The brick is in bad shape, with cracked mortar and even loose brick. Triple chimney, 1 for furnace, the other 2 for wood burning fireplaces. Customer is concerned he may have to replace the entire chimney. Is is possible/recommended to repair the brick, and line chimney? [/quote]
This is going to need three liners.......and they will not be separated by a wythe of brick. Looks like a re-build!! In Canada, each fireplace must have its own flue. |
BestInspectors.Net
& Real Estate Training Academy Inspection Report Software for Windows - iOS - Mac - Android Continuing Education Home and Commercial Building Inspection - Skilled Trades – Real Estate – Appraisal – NFPA 921 http://www.bestinspectors.net est. 1992 |
See it all the time in Kansas City / Usually in older homes (1900-1950).
Refer them to masonry specialist or chimney specialist for recommendations for repair, relining, etc and keep moving. |
Also observe the quality of flashing installation at chimney/roof deck. Water intrusion can deteriorate non-visible mortar.
Neighbors chimney.....my house.....Tuesday. They're getting a new roof/tear-off done by "friends" (unlicensed roofers). Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| Flue through brick chimney | jgromkoski | Inspecting HVAC Systems | 4 | 8/5/10 7:00 AM |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 5:08 PM |
