Has anyone seen this before on the corners of brick veneer?
Josh Mayfield Coastal Building Concepts, LLC www.coastalbuildingconcepts.net Florida Licensed Home Inspector #HI1880 InterNACHI Certified Home Inspector #10100102 Serving Pensacola, Pensacola Beach, and Gulf Breeze |
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I have seen similar openings used as weel holes. They are typically spaced evenly across the brick veneer, not just in the corners.
Those are not weep holes.(wrong location)
I see cable in the background off the first picture however so did you see those holes or look for them on the other side. Perhaps downspout bracket holes and missing downspouts? |
Recommend tuck pointing and be done with it. Doesn't appear to be structural in nature.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Yes, I have seen them before...
They are there to let water into the wall system... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
thanks.
to back flush the weep holes.
Would be like backflushing the toilet, huh Nick, you would get all kinds of crap under the shingles.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
You guys are really BAD!
Where is your sense of humor? Can't take a joke?
| Why do brick spall? | mbryan | Exterior Inspections | 68 | 9/1/11 10:10 PM |
| Brick veneer flashing | mklein | Exterior Inspections | 6 | 2/21/10 4:20 PM |
| Backfill on brick veneer | bpaull | Exterior Inspections | 4 | 7/12/07 7:40 AM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 6:34 PM |
