Old 4/27/07, 10:52 AM
Bob Elliott's Avatar
Default Build A House (ae)(af) footing
The basic first step for a foundation is the footing.
This will support the weight of the entire structure.
Why is it done separately? Why not pour the foundation walls at the same time?
http://www.chicagolandhomeinspection.com/id62.html (alternate images)
Old 4/27/07, 12:11 PM
Peter C. Russell's Avatar
Default Re: Build A House (ae)(af) footing
Don't you use re bar in your footings?
Out my way the footing get poured and re bar rods inserted into the concrete to dry. The next day it gets inspected and the foundation wall forms are built and poured.
Old 4/27/07, 12:15 PM
Here's a couple of the walls.
Old 4/27/07, 12:25 PM
cbellefontaine's Avatar
cbellefontaine cbellefontaine is offline
Send a message via MSN to cbellefontaine
Hi Pete,
I know this is Bob's show, but I know he won't mind if I chime in once or twice. Around here we use keyways to keep the bottom of the foundation wall from sliding off of the footing. I am sure the rebar will work just fine, but as usual, the almighty dollar prevails and a keyway is cheaper than rebar. That is the groove that is shown in Bob's picture. Usually they are not that clean.
Bob, you asked why they don't pour them at the same time. You would have to box the top of the footing to keep the concrete from coming out since the walls are thinner than the footing. In doing so, air would be trapped and there is no way to confirm that the concrete fully filled the void. Another reason is removing forms from inside corners is a pain in the *&^.
Sincerely,
Charles M. Bellefontaine
Bellman Group, Inc.
877-316-0600 Extension #802
Click Here to Join our Email Newsletter
Get Illinois Home Inspector Pre-License Education and
Continuing Education at www.bellmangroup.com
Low cost professional report writing with a contact
management system. www.myreportwriter.com
Old 4/27/07, 1:02 PM
Hi chuck..This is great stuff and exactly what I am hoping to accomplish.
You may have missed out on my other threads but this is a mini -forum on building a house and you contributed the way I hope for from all members who see these pics.
It was not a real question as having you as a teacher taught me to continue educating myself and others.(Good job.)
For anyone who does not know .Chuck was my educational instructor.
Old 4/27/07, 1:05 PM
Good pics.
Old 4/27/07, 3:56 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Originally Posted by cbellefontaine
Hi Pete,
...I am sure the rebar will work just fine, but as usual, the almighty dollar prevails and a keyway is cheaper than rebar. That is the groove that is shown in Bob's picture. Usually they are not that clean.
Almost always never that clean. What's even worse is the lack of keys or rebar in some new construction, all too common.
Thanks for posting these pictures as construction goes along. This is great educational stuff for those that have never experienced new construction.
Old 4/27/07, 5:26 PM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is great stuff, Bob, and a valuable service you are providing. Are you posting this on Localism.com?
Old 4/27/07, 6:25 PM
Originally Posted by relliott
Good pics.
Hi Bob, just thought it would be interesting to show how things are done in different parts of the country, Don't want to interfere, hope you don't mind.
We started framing and I have some good pictures of how I insulate floors over an inaccessible crawl space, I can post if you would like to see them or if you want to keep this about your project that's fine too.
All good info. for are members though!
Old 4/27/07, 11:56 PM
Hi Pete ..sorry I did not get back sooner but your got me so mad that....
Nah just kidding, sure great idea ,this is all about seeing the guts of what is inside the things we inspect.
We are doing a visual non destructive inspection,and sometimes there are cases where we lose tract of the big picture in how things interact.
Please post and explain why the crawlspace is not accessible
Old 4/28/07, 7:01 AM
homebild homebild is offline
Rebar in footings is not required under the International Residential Code.
Keyways are not there to replace rebar in walls. Keyways are used for poured concrete walls to help the walls resist lateral forces at the bottom.
Rebar is not required in foundation walls that will be as shallow as shown in the original pictures.
Old 4/28/07, 7:27 AM
Hi Bob, Thanks, the crawl space I mentioned is over a breezeway with no bulkhead or access from the basement.
I have developed a system to ensure proper R value plus make sure the insulation stays, this also provides a protective barrier for the fiberglass.
I strap the bottoms of the joists, then rip 1" foam insulation to fit between the joists and then add R-30 fiberglass, the result is a R-35 floor, here are some pic"s
Old 4/28/07, 11:59 AM
would look forward to seeing a few more pics with detail on the framing attachment
Old 4/28/07, 12:47 PM
dhelm's Avatar
dhelm dhelm is offline
It is probably wise to check local codes before deciding to go rebarless. Some areas, mine included require rebar in footings and stem walls, regardless of height.
About the only time footings are poured along with everything else is on slabs where a monolithic pour is allowed.
Helm Home Inspection
David Helm, Owner/Inspector
http//www.helmhomeinspections.com
Old 4/28/07, 2:26 PM
Hi Bob, we are standing walls on Monday, what did you think of the insulation in the floor?
Stupid ASHI legislatin in Washington DEAD. gromicko Legislation, Licensing & Legal Issues for Inspectors 20 1/29/08 9:05 AM
Build A House (am) (an) belliott General Inspection Discussion 68 5/31/07 12:14 AM
Build A House (ag) Nah! but it would be fun belliott General Inspection Discussion 6 5/2/07 3:22 PM
