Old 7/26/06, 12:23 PM
cthorsen cthorsen is offline
Question A/C Temperature Differential
An open question. What is the correct temperature differential between the supply and return on a central A/C system. I have read or heard anywhere from (11 to 15 degrees) to (14 to 20 degrees). Using an infrared thermometer I seldom register above 14 degrees. I have replaced batteries and made sure I'm not more than 2 ft away from a register thinking it was the thermometer. I had one instance on a new house where I could not get more than a 9 degree differential. I ran the A/C for more than 45 minutes and could not get the room temperature below 76 degrees (according to the thermostat the temperature started at 78 degrees). I reported this as needing to be checked by an A/C contractor. I later heard through the realtor that they found no problem and I probably didn't know how to work the thermostat. The system was 42,000 BTU for a 1800 sq ft (under air) house. Should I be using a different type of thermometer? Any comments?
Old 7/26/06, 12:38 PM
Michael R. Boyett's Avatar
Default Re: A/C Temperature Differential
Craig...1st read all 117 posts in this thread: http://www.nachi.org/forum/showthrea...t=differential . If you're still confused come back to this one...
Old 7/26/06, 12:39 PM
gbeaumont's Avatar
Craig,
there has just been a big discussion on this topic in the HVAC section
Click here for enlightenment
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 7/26/06, 1:47 PM
Brian E. Kelly's Avatar
Whats the normal temperature for breakers jtaylor5 Electrical Inspections 15 11/6/07 9:15 PM
Heat Pump temperature differential jweinberg Inspecting HVAC Systems 13 12/13/06 8:59 AM
Temp differential dlee2 Inspecting HVAC Systems 4 8/22/06 11:01 AM
Checking temperature of breakers bking Electrical Inspections 18 7/28/06 8:45 AM
Heat Pump psmothers Inspecting HVAC Systems 66 7/20/06 12:15 PM
