Go Back   InterNACHI Message Board > General > General Inspection Discussion
Old 11/9/08, 9:01 PM
hmiller's Avatar
hmiller hmiller is offline
Please Note: hmiller is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Cameras - what do you use?
So this post comes out of a never ending frustration of digital camera problems. .......Maybe I am just hard on cameras.
My current victim is a Sony Cybershot DSC-W80. I have taken only a dozen photos and already I am having a problem with the lens opening and closing with an error message that will not go away. It is going to be sent in under warranty.
This camera replaced an HP M537 Photosmart, which was replaced under warranty last May. In fact this was the third HP I have had.
Prior to all these I had a couple Canon Powershots. Every single one with problems of one sort or another. LCD screens that stop working, zoom lenses that have issues, and so on.
Now I am pretty confident that my problem is that I am "getting what I paid for". Since most of the cameras I have owned all cost somewhere between $100 and $150, it seems that maybe I am expecting too much from cameras in this price range.
After all most people who buy these pull them out every once in a while. On the other hand, we have ours out every day, and likely place them through more challenging conditions.
So now I am looking to upgrade to a more durable camera, and wanted to pick the brains of my fellow NACHI members to see what people are using, and what has been reliable. Thanks!
Old 11/9/08, 9:05 PM
James F. McKee's Avatar
Default Re: Cameras - what do you use?
Good question Harold ....i have been having similar issues myself ....so what say ye folks...what is the digital camera for the home inspector these days????
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 11/9/08, 9:09 PM
Ralph Brady's Avatar
Ralph Brady Ralph Brady is offline
I have tried a few different cameras and have had very good luck with the Olympus D-580 & D-560. Some other cameras did not seem to have sufficient flash for one thing. The worst was a HP. The last couple of Olympus's I bought on ebay for less than $100 - they are older models, but I don't need more than 2 -3 megapixel. My cameras pretty much always wear out (or break when I drop them onto concrete) after about a year. When I get a new one, I delegate the previous one to the crawlspace. I alway get one that uses AA batteries, and I use rechargeables.
Edit: I alway make sure the camera has at least 3X optical zoom also.
"An expert is a person who has made all the mistakes that can be made in a very narrow field"
Niels Bohr
"Learn all you can from the mistakes of others. You won't have time to make them all yourself"
Alfred Sheinwold
Eureka, Fortuna & Arcata, CA
Old 11/9/08, 9:11 PM
Doug Edwards,  CMI's Avatar
Harold,
I had numerous problems with my cameras until I bought my first Pentax Optio Water Resistant camera. It is compact, comes with great software, takes great photos. I like it so much I bought two more just to have a spare on hand and one in reserve. The telephoto/zoom (2.8x optical) function is built internally so there are not any external moving parts for grit to foul up the works. If I get it dirty or it gets wet, I can run it under the hose bibb to rinse it off. My model (WR-33) is no longer available but there are newer models that are suppose to be even better. I bought a water resistant camera after one of my earlier cameras gave up the ghost from moisture. For our line of work, I figured a tough,water proof camera was the way to go.
Doug Edwards, CMI
Old 11/9/08, 9:42 PM
Andrew MacDonald's Avatar
Andrew MacDonald Andrew MacDonald is offline
I use the Casio Exilim EX-V8. It uses mirrors instead of a ratcheting lens. You just slide the lens cover to turn camera on and off. I had the same issues with lenses that protrude from the camera body. 2 years and thousands of shots and no problems what so ever.
http://www.shopcartusa.com/P_Casio_E.../?ic_campID=98
Andrew MacDonald
MacDonaldPropertyInspections.com
InsightThermalDiagnostics.com
ITC/FLIR Certified Building Science Thermographer
ITC/FLIR Certified Level 1 Thermographer
Old 11/9/08, 9:44 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Canon SD 1000 and 1100's
Old 11/9/08, 10:24 PM
I have three of these, one of them is pretty beat up.
http://itemlistings.ebay.com/sdcsrp?...ax.Value%3D319
"Never ever threaten anyone in Camoflage"
Tim Wilson
"Not everyone follows the same path"
Governor Sanford, musings on the Appalachian Trail
Old 11/9/08, 10:32 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Kodak Z710 and a Canon 40D.
Old 11/9/08, 10:57 PM
pdoane's Avatar
pdoane pdoane is offline
Please Note: pdoane is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hands down! Kodak EasyShare C310 is the most perfect inspection camera for $100.00
I've gone through soooo many cameras (5-6) the kodak C310 has been the last one I've purchased and is still going strong even with abuse over two years now. It goes on the roof, attics, and dirty wet crawl spaces.
I get complements all the time about the pic quality in my reports, some think I'm using a 10-12 pixel camera. Nope. Its a lonely 4.0 that I actually have set on 3.0. I attached a sample pic of its clarity.
Old 11/9/08, 11:08 PM
David A. Andersen's Avatar
I own every Sony camera I ever purchased, still working.
I crapped out several cannon and HP cams during the same period.
All I can say.
ITC Certified Level II Thermographer Cert#1958
Old 11/9/08, 11:45 PM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
Pentax Optima
No moving parts. Waterproof. Great camera.
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/10/08, 5:11 AM
Stephen W. Stanczyk's Avatar
I have to agree with Ralph. I like the Olympus D-580. I get them used on ebay or reconditioned for anywhere between $40 and $80. Takes great pictures and with a High speed 1GB card I can get a lot of high quality pics with little waiting time between flashes.
Stephen Stanczyk
Structural Pest Inspectors License # 71043
Vice-President, Washington Association of Property Inspectors (WAPI)
Old 11/10/08, 8:16 AM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
For price, ease of use, etc., I use Kodak EasyShare Z712IS or C310.
Another camera I have started using is the Flip video camera. This is an awsome little camera that I use to quickly video every room of house and outside before I leave... more of a CYA for my own records. I like to video locking up and turning everything off if I am alone in a foreclosure. Flip
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Old 11/10/08, 3:17 PM
Rick A. Harrington's Avatar
Rick A. Harrington Rick A. Harrington is offline
I am currently using a Sony Cybershot DSC-H2. I have used Fuji, Cannon and Kodak as they were available when I started.
What I like about the Sony is the wider Field of View and the ability to take great pictures in little to no light.
This model of Sony Cypershot also has the ability to add many different lens adapters including wide angle and telephoto.
A chimney on a 3 story house can seem as close as your hand in many instances and clear even on the lowest resolution.
Out of the box without any special settings I took the attached picture.
Rick A. Harrington
Patch Independent Home Inspections, LLC
Serving Columbus and Central Ohio
Certified Specialist - Infrared Residential Inspections Advanced
Certified Mold Inspector
State of Ohio Licensed Radon Tester
http://www.patchhomeinspections.com
http://www.centralohiohomeinspector.com
http://www.columbusohiohomeinspector.com
http://www.thermalimagescanning.com
Old 11/10/08, 3:37 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Buy cargo pants, and make sure to use the wrist strap
New Thermal Imaging Cameras Leslie Tack Thermal Imaging, Infrared Cameras & Energy Audits 0 11/1/08 1:30 PM
Infared cameras rchorey General Inspection Discussion 36 9/24/07 6:55 PM
What batteries do you use in cameras? wwarner General Inspection Discussion 18 2/6/07 11:28 AM
Flir B-Cam vs. B2 vs. Fluke Ti20 vs. Ti30 Thermal Imaging Cameras Dave Downing General Inspection Discussion 5 2/2/07 10:45 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
