Do you think that this might be carpenter ant dust?? I did not see any wood damage or body parts. Some wood rot in this area on the exterior?
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Colorado Home Inspector (and anywhere else in North America) |
got any other pictures Buck? where was that shot in the house...basement? attic?....almost looks like blown in insulation to me in that picture....jim
In the corner of the basement, behind the insulation at the rim joist. Only pic I have.
well in that location you well may be right Buck...especially if there are exterior signs, probably a safe bet....
Jim.
I call it! Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Buck, you only need to remember that Carpenter Ant Frass will be the color of whatever they are tunneling into, cause they don't eat wood and moisture is a problem because that is why they are there to begin with. Look around for more clues.
Recommend further evaluation by WDO specialists rather than call it wrong. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Carpenter Ants | cbuell | Interior Inspections | 15 | 4/12/11 10:29 PM |
| Carpenter ant evidence? | dokeefe | Ancillary Inspection Services & Additional Topics | 12 | 7/31/09 7:26 PM |
| Ants Swarm Houston Area, Fouling Electronics | jonofrey | Miscellaneous Discussion for Inspectors | 1 | 5/16/08 8:20 PM |
