Old 4/6/10, 10:22 AM
Randy Mayo Randy Mayo is offline
Please Note: Randy Mayo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Cool Chart of Common Problems
Does anyone know if a detailed chart or percentage listing of common problems found in home inspections exist? For example out of 10,000 inspections 15% had drainage issues, 5% had structural problems, 32% had electrical problems,etc.
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/6/10, 12:34 PM
Nick Gromicko's Avatar
Default Re: Chart of Common Problems
We did one study showing that less than 1% of all defects uncovered in the average home inspection report had anything to do with the system or component not being installed to code.
Find a Home Inspector
Old 4/6/10, 2:17 PM
My top 10.
http://www.metrospeckc.com/Home_Inspections.php
Scroll to bottom of page.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
"If opportunity doesn't knock, build a door"--Milton Berle
Old 4/6/10, 5:15 PM
Brian E. Kelly's Avatar
The last study I saw mentioned Roofs first...I think it was an ASHI study.
Old 4/6/10, 6:23 PM
Greg Keene, CPI's Avatar
Greg Keene, CPI Greg Keene, CPI is offline
Gary - Great list - find many of those on every inspection - I would add garage door springs not adjusted (pull the rip cord and SLAM!), and not reversing when encountering an obstacle. I find those on about 70% of the homes.
Greg Keene
Clear Choice Home Inspections
Evergreen, CO
303-674-3234
greg@clearchoice-hi.com
Old 4/6/10, 11:47 PM
Any reliable survey is contingent upon how thorough the inspectors are that are giving the information as well as how nit picky you want to get; with that said, most problems originate at the exterior of the home....... from there other systems and components are affected. Most of the issues I see are grading and general water management issues. When I say water management issues you are primarily dealing with roofing and the exterior veneer.
As far as inside is concerned, the major issues I see crop up are insulation / air infiltration issues..... followed by plumbing, hvac and framing.
Framing and foundation issues by far are the most expensive.... failing to detect those issues can cost you tens of thousands of dollars......those are the areas that I say most home inspectors are weak at.... which is understandable since few inspectors actually come from that particular background.
regards
Jeff
Old 4/7/10, 1:08 AM
John McKenna's Avatar
John McKenna John McKenna is offline
Moisture related issues is #1 by far.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 4/7/10, 1:22 AM
Tim Spargo's Avatar
What John said...
Moisture.
Moisture will cost your clients money in many shapes and forms and it always wins.
AC unit goes bad... replace it.
Poor grading and drainage... big bucks
and so on.
Tim Spargo
Spec Rite Inspections
661-317-5770
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Why was the Inside System sold/installed without FIRST identifying the problem(s) john bubber Structural Inspections 0 2/20/10 6:14 AM
Preventing Moisture related Problems mcyr Ancillary Inspection Services & Additional Topics 1 12/19/07 8:30 AM
Hire IAQ Professional dplummer Ancillary Inspection Services & Additional Topics 0 11/15/07 9:01 AM
