Leanne Jowers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Should NACHI inspectors note if there is zero clearance to combustibles next to a masonry chimney?
L. Jowers |
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't understand?
The exterior of a masonry chimney does not,should not, get hot.Therefore no clearance would be needed. Are we talking about the actual chimney?...The hearth?...The mantel?...Opening around the fireplace?...NACHI?...A specific NACHI inspector?... Last edited by ckratzer; 3/29/07 at 10:17 AM.. |
http://www.rumford.com/code/clearances.html Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
What state are you from Leanne?
Actually, I would bet that...like Walter Jowers....she is from your state and that her agenda here is NOT to be of benefit to NACHI. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Leanne
Without specifics as to the issue, its not possible to provide an answer based on what you have asked. More details are required. Please elaborate. |
Damn it James!
You blew my cover! |
| Combustibles inside fireplace? | bmargiotti | General Inspection Discussion | 8 | 11/19/07 11:41 AM |
