B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Odd seeing as how Barry loves ASHI so much.
I don't know any ashi inspectors that remove covers on furnaces.
Is it really required? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Bruce you being serious or cutting up? lol
Bill Boerner STL Home Inspection ServicesServing St. Louis/Surrounding (314) 805-2137 billy.boerner@gmail.com http://www.stlhomeinspector.com |
Only if you want to see anything of interest.
Removing furnace covers is not required directly by any SOP that I have seen, they all have an opt out clause in there somewhere.
Now, the ashi sop is the one that does appear to have it but as I said before, no ashi inspector I know removes the covers on all units. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 8/17/08 at 10:41 PM.. |
acox is a non-member guest and is in no way affiliated with InterNACHI or its members.
Did anyone notice on the page below barry's column, there's an ad for "Inspect It Yourself"? It's pretty interesting.
Here is what I found at your link above: C. open readily openable access panels provided by the manufacturer or installer for routine homeowner maintenance. Most inspectors assume that panels for routine homeowner maintenance are only the filter panels. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
So on what assumption do you base routine furnace maintenance?
The correct term from your sop is " routine homeowner maintenance" not "routine furnace maintenance" Big difference.
I'm not saying that we should not open furnaces that are readily accessible but am saying that no sop actually requires it except maybe ashi (their definitions are not listed within their sop on their web page to confirm either way). B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Here's Illinois SOP . Water downed ASHI. It's really kind of vague.
l) When, pursuant to the written agreement with a client, the heating system is inspected, the home inspector shall: 1) Inspect the installed heating equipment, the vent systems, flues, and chimneys; and 2) Describe the energy source, the heating method by its distinguishing characteristics. Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
There is nothing in a furnace besides the filter if it's located at the Air Handler a homeowner should be opening not knowing what the heck their doing--- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Bruce,
Your absolutely right. Bottom line is the NACHI SOP states we will operate the system under normal controls and report if it works or if it needs repairs since it didn't operate. However, most inspectors I know opens up the cover panel including myself. Bill Bill Boerner STL Home Inspection ServicesServing St. Louis/Surrounding (314) 805-2137 billy.boerner@gmail.com http://www.stlhomeinspector.com |
The main point of this thread was to get some opinions on the ashi sop since that was the one referenced in the article.
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 7:11 PM |
| Requiring Money Order or Cash | Erol Kartal | General Inspection Discussion | 7 | 7/22/08 9:48 PM |
| AC check list | jcahill | Inspecting HVAC Systems | 10 | 7/17/08 7:33 PM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 11:43 PM |
