Comments anyone?
http://www.masoncountypress.com/2012/02/home_tips.html |
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks great I am a bit concerned about 125°f . Most of what I have read is 120°F . WE have ours at at 108°F and are satisfied . |
I have heard both, that's why I suggested anything over 125 be turned down.
The article looks good.
Here is a water heater settings chart: TIME/TEMPERATURE RELATIONSHIPS IN SCALDS* Temperature Time to Produce Serious Burns 120°F More than 5 minutes 125°F 1- 1/2 to 2 Minutes 130°F About 30 Seconds 135°F About 10 Seconds 140°F Less than 5 Seconds 145°F Less than 3 Seconds 150°F About 1-1/2 Seconds 155°F About 1 Second 160°F+ Instantaneously *Table Courtesy of Shiners Burn Institute InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
WE in Ontario the Tank temp must be maintained at 140°f to stop legionnaires disease .
So all new ( since 2003~) need a tempering valve to mix the hot and cold to get a tap temp at 120°F or lower . |
Great job, Mike.
Nice work...
The $180.00 savings a year is misleading. Unless you are getting a year round heating bill of $150.00/month. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Nice article Mike.
Congratulations on having a great marketing outlet. |
I would add that the furnace filters should be the cheap, blue fiberglass type. Low air blockage. Not the Filtrete filters.
And, you can "lightly" spray the filter with Pam cooking spray on the return side for more dust catching. Just don't use the "butter flavored" version. ;^#()] Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Thanks Will.
Can I add some popcorn kernels? Where did you hear this? |
| Evaluating your home's wiring system | mcyr | Electrical Inspections | 0 | 12/30/09 1:31 PM |
| Procedural Inspection Checklist | bgromicko | Electrical Inspections | 11 | 3/8/08 11:47 PM |
| Procedural Inspection Checklist | bgromicko | General Inspection Discussion | 0 | 3/8/08 10:40 AM |
| inspection procedural checklist | bgromicko | Electrical Inspections | 24 | 3/2/08 10:00 AM |
