Comments solicited on following standard text. There is a "gotcha" to it. I'll post it later.
"The composition roof has worn flashing and two missing shingles. Much of the remainder of the roof appears undamaged. Replacement of the entire roof is recommended as the only way to guard against defects not found.". "The concrete slab has slight movement at the corner of the garage. Much of the remainder of the foundation appears undamaged. Piering of the entire foundation is recommended as the only way to guard against defects not found." |
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What do you mean by "Standard Text"???
I have never seen "Standard Text" before. |
Standard text aka boilerplate. It is wording that would be used on almost every report. |
Sounds more like, "I found a little problem, best rebuild that whole area just in case".
That it is Boilerplate, in and of itself is not the problem. The problem is they are poorly worded Narratives..IMO. |
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Replace the entire roof because two shingles are gone? I would be embarrassed to put that in my report. As for the garage slab in my area they are poured separate from the foundation and are cracked all the time. |
Same here
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
The slab narrative is faulty. Suggesting piering, helical devices or whatever else from what may be perceived as some defect or another is getting into providing remedies for significant defects. That's not a great idea IMO. "The faucet drips and may need a cartridge/washer etc" has it's place.. saying that a slab has *slight* movement and needs XXXX to prevent future defects is a goofball idea. *How* is the movement SLIGHT? Did you measure the slab's level? And so on and so on. Narratives suggesting that we can measure a foundations performance in the absence of a significant defect as a HI is a set up for failure. |
OK guys and gals. I warned there was a catch 22. Here it is. This is regarding the dome that collapsed in Minnesota. The engineers said:
"Engineers wrote the full replacement of the 10-acre roof was the only way to guard against another deflation from defects they might not have found. Several panels ripped under the weight of the snow, but many others appeared undamaged." Here is the link. http://www.propertycasualty360.com/2...f-snow-damaged I found it amusing. |
The stadium has a fiberglass fabric roof that is self-supported by air-pressure.
I see no problem with the engineers report in this case. It has nothing in common with the type of structures we inspect so no comparison to report wording should be done. I liked the old inspection they had that found some holes and they recommened the holes be monitored to see if they get any bigger. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Insurance is going to pay so the engineer says replace it all because I am not sure I found all the defects. Its a totally useless engineering comment. Its stupid; but if they got paid it is brilliant. In some ways it is similiar to home inspection. If an inspector arrives at a home with very minor hail damage and the owner says "the insurance company is going to replace the roof" do you think the inspector will disagree even if the roof is in excellent condition? I just found the article to be funny. BTW how many home inspectors, Realtors or lawyers would they have to put in that stadium to inflate it? |
John
The level of caution an engineer or engineering company will use depends on several factors. Here are the top three in my opinion:
The last one trumps all others. In the case of this air supported dome the engineers have to consider the level of design complexity which is high, the documented history of this happening which is nil, and the potential for loss of life which is high. So when uncertainty is high error on the side of safety. Residential structures are at the low end of the complexity scale, there are thousands of years of documented performance data so the potential for loss of life is very low. Which is why the need for such extreme disclaimers for home inspectors is not needed. |
Heh... that's another way of looking at it.. "I noticed one of the windows was difficult to operate, you may consider cleaning the tracks/replacing rollers etc OR Replace ALL the windows as this is the only way to guard/ensure that the windows will function properly." An *entire* new way of reporting can be created. |
I recall getting a call a few years ago to come out and look at a home that had been inspected by another company. Windows- The living room window crank did not operate. It is recommended that due to their age, all of the windows in the home should be changed to hurricane rated windows, immediately, to prevent any further damage to the structure. It got worse from there on. |
| newbie fuse panel question | tlarsen | Electrical Inspections | 4 | 4/14/09 5:55 PM |
| Check valve first time for everything????? | cbottger | Plumbing Inspections | 5 | 4/8/07 1:43 AM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 10:43 PM |
| Mildew in hallway | Steven Brewster | Ancillary Inspection Services & Additional Topics | 18 | 1/12/06 1:03 AM |
