I recently did an inspection of a house that had a flue pipe for a wood burning stove running up the exterior side of the house and through the soffit and roof above. Siding is T-111 and untreated wood shakes. The flue comes within 6" of the siding. I could not find any documentation for the fireplace and am not sure what the current building requirements are. Can you all give me some advice on this?
Terry |
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
6" spacing would apply to single wall. That picture shows at least a double wall and possible triple wall. It may actually be "Zero" clearance acceptable. OEM safety info should have been stamped into the material.
Good Luck! |
Not sure what type of flue that is. There should be mfrs. markings on the flue pipe.
It it's type HT it needs to be 2" minimum to combustibles. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Thanks guys!
appreciate it. Terry |
It's triple wall and 1" clearance to combustibles is OK for vertical runs. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Will never said single wall was OK for zero clearance. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
You claimed Will "missed" something. What did he miss? No harm no foul Larry. I apologize again for my hastily composed and erroneous post. I have only seen "zero clearance" refer to the fire box portion of manufactured wood burning fireplaces and those usually have some type of stand off built into or attached to the outer shell. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Larry have a nice evening.
| Clearance Testing | tfarmer | Ancillary Inspection Services & Additional Topics | 15 | 2/26/08 5:41 PM |
| chearance to combustibles | Leanne Jowers | General Inspection Discussion | 6 | 5/14/07 10:49 AM |
| Range Clearance | dsmith6 | Interior Inspections | 18 | 1/7/07 9:55 PM |
| Siding to Ground Clearance | tneumann | Exterior Inspections | 14 | 2/8/06 11:48 PM |
