Hi,
I'm relatively new to the home inspection business and just been asked to do a commercial inspection. As I don't know much about inspecting commercial property, I thought I'd ask here. Is there much difference between residential and commercial inspections? Is special certification required (I am in Canada)? Any insight would be greatly appreciated. Howard Walsh Seacliff Home Inspections Windsor Home Inspector http://www.seacliffinspections.com hwalsh@seacliffinspection.com Serving Windsor, Essex and Chatham-Kent |
Go to the commercial section.
(on this MB) |
If you understand how a commercial building is constructed, which is much different than residential you shouldn't have any problems. Few Examples: Three phase wiring, roof coverings, structural components, etc. etc. Also look at the nachi commercial sop, that might give you some more insight if you plan on following it. (I don't, but some folks might) www.nachi.org/comsop.htm Define a scope of work between you and your client, the most important aspect of any commercial inspection, so each party is on the same page, and add the scope of work to your inspection agreement. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Thanks for the input. I'll check out the commercial section. Don't think I'll take this one right now. Don't think I ready.
You might want to think about partnering with someone who has commercial experience so that you get an opportunity to learn and your client receives a proper inspection. "A state of war only serves as an excuse for domestic tyranny." ~ Alexander Solzhenitsyn Certified Master Inspector (2007) Member, International Assoc of Certified Home Inspectors (InterNACHI) Member, International Code Council (ICC) - Certified Residential Combination Inspector Square-One Inspection "Assurance begins here"
Joe Burkeson is correct. You can take the inspection but hire outside consultants using the Professional Services Contract (between you and your consultants) at http://www.nachi.org/comsop.htm#12
In other words, act as a General Contractor and use qualified subcontractors to do the inspection using http://www.nachi.org/comsop.htm#12 Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
| Commercial Real Estate Doing Better than Housing | jbushart | Miscellaneous Discussion for Inspectors | 3 | 10/23/07 9:34 AM |
| Commercial Building & Thermal Imaging Course Coming to New Hampshire | fcarrio | Commercial Inspections | 1 | 8/13/07 12:47 AM |
