dsearcy is a non-member guest and is in no way affiliated with InterNACHI or its members.
While inspecting a concrete tile roof I noticed that all the seams in the tile lined up with the seams of the row above it. I was under the assumption that the seams should be staggered. Now I know what happens when we assume something, that is why I am coming to the people in the know. Any help on this matter would be greatly appreciated. Don
| Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America) |
Here's what I normally see on a daily basis, it would help if you posted a photo. Hope this helps. And yes they should be staggered.
Mike Chris, Santa Clara, Utah
NACHI: #05051385 HouseNspect@gmail.com www.housenspect.com activerain "A man's home is his castle . . . until the queen arrives." |
Donald, off the top of my head, Jeff Pope, Louie LaFleur, and Paul Pendley, might chime in to help or other inspectors in California.
In the meantime, you can review this;\ http://www.nrca.net/consumer/types/tile.aspx#details LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Photos would be helpful. Im sure you had a camera with you.
Anytime you inspect not only a roof but anything that is supposed to be water deffering, keep in mind that water is lazy and will travel on the least path of resistance. Hope that helps.
| concrete roof tile over asphalt shingles | Scott Schultz | Exterior Inspections | 1 | 3/29/07 6:32 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
