Old 9/28/06, 5:01 PM
sgould sgould is offline
Default conflict of interest?
I just had a call to inspect a home that I've worked on withing the last six months. I've told the prospective client that I did work on the house. Is this still considered a conflict of interest? Should I ask them to contact another inspector? Thanks.
Old 9/28/06, 5:04 PM
Carl Pennick's Avatar
Carl Pennick Carl Pennick is offline
Default Re: conflict of interest?
The fact that you done the work before hand, have told your client I cannot see any reason as to why you cant do the inspection. Should there be any work required after the inspection then that's a different matter.
www.wisemovehomeinspection.com
Carl Pennick
Lighthouse Point, FL
954-946 2737
407-928 8489
Florida Licensed Home Inspector #65
NACHI #04072098
ICC #5294144
Certified Master Inspector
Old 9/28/06, 5:08 PM
I agree with Carl. IMO, as long as everthing is out in the open, have at it.
Larry Kage, CMI
231 929 3525
Old 9/28/06, 5:41 PM
James H. Bushart's Avatar
Steven,
This has bothered you enough to ask the question. What are your thoughts on this?
Old 9/28/06, 5:46 PM
I'm not at all bothered by doing the inspection as long as NYS has no issues with it. I seem to remember some specifics as to recent NY law regarding contractors and inspectors wearing the same hats during a specific period of time.
Old 9/28/06, 5:53 PM
rnewman1 rnewman1 is offline
Send a message via Skype™ to rnewman1
I do not know what work you performed but, how could you be impartial ?
Old 9/28/06, 6:09 PM
Jeffrey R. Pope's Avatar
Yes. It's a conflict.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/28/06, 6:16 PM
Doug Edwards's Avatar
I think if you have to ask, then it is a conflict. Try to avoid even the appear of a conflict. If later on there is a problem with the areas that you contracted for then they could very easily say you were not impartial to those areas during your inspection. Whether you were or not it would be questionable even for the most impartial juror. You didn't say what exactly you did and it may be very benign.
Old 9/28/06, 6:27 PM
Michael Larson's Avatar
Is it a conflict if he discloses the fact that he worked on it recently?
It also may not be the same owner at the present time.
Old 9/28/06, 6:36 PM
Roy D. Cooke, Sr's Avatar
It easy to report shoddy work But If it is your work that is not good how can you report it . Roy Cooke
Old 9/28/06, 6:43 PM
I understand your point but if both parties enter into agreement with all the facts disclosed where is the conflict? That's not to say one may overlook his previous work if he is dishonest.
Shouldn't the buyer bare some responsibility in hiring the HI he chose?
I probably wouldn't do it either but it would depend on a number of factors.
The best advice is probably - if there a question or it doesn't feel right, pass on it.
Old 9/28/06, 7:11 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
So if I installed hardwoods in a house 7 months ago, I ethically can't inspect it today ??
Old 9/28/06, 7:31 PM
Mark H. Roe's Avatar
Mark H. Roe Mark H. Roe is offline
It is real easy to solve your problem. Go back and re-read the law the NYS set up concerning this matter. If your work that you preformed falls in the time frame then you are in conflict with the NYS law. Problem and conflict solved.
Old 9/28/06, 10:14 PM
Yes it is. You cannot give an impartial opinion on work you performed as a contractor. The best you could do, short of declining the inspection, is to disclaim and not inspect the areas of work where you provided the service.
That would not matter. It's still the same house, regardless of how often it changed hands.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/28/06, 10:20 PM
Joseph Hagarty,  CMI's Avatar
Agreed.
You are contracting to perform an assessment of the work that You performed within the home in the last 6 months.
Can you Arguably (Legally) present a report where comments related to your work performance are not suspect?
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Is this a conflict of interest? Janie K. Stough General Inspection Discussion 47 1/27/07 10:40 AM
Certified Home Inspector or CHI Designation rwand1 Canadian Inspectors 42 6/9/06 7:57 AM
Kansas Licensing Bill dbowers Legislation, Licensing & Legal Issues for Inspectors 18 2/21/06 8:51 AM
