According to mold industry standards, I am required to have a crawlspace fan installed when there is mold in a crawlspace, unless for some strange reason the client wants the crawlspace clearance tested. Which cleaning a crawlspace to pass an air test is very labor intensive and expensive. All vents have to be closed so the fan creates a slight negative pressure and pulls conditioned air from the level up above.
I was talking to a waterproofing company and they claimed crawlspace fans cause what they called a reverse stack effect. A crawlspace fan only completely changes out the air in a crawlspace about every 15 minutes. I do not see how this could cause smells coming from the attic like they claim, unless possibly the attic is not properly vented. Any thoughts would be greatly appreciated. Last edited by jbraun; 9/3/10 at 8:05 AM.. |
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yes I think it could cause Air from attic getting into the home .
Fan generates positive pressure in Crawl space and negative pressure in home . Small holes from Crawl into Wall cavities like electric wires Plumbing vents and pipes. Air gets to attic negative air in home pulls air from attic Via attic entrance or wire holes ect and you have smell if it is in attic . The difference does not have to be much for this to happen . Need help on inspection call my cell 613-827-2011 Questions ( I like email ) Roycooke@hotmail.com "All that is necessary for the triumph of evil is that good men do nothing"----- - -Edmund Burk Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. http://www.nachi.org/forum/f5/intern...html#post90964 |
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have installed hundreds of fans systems in sub-structures and never had any condition occur like what you are talking about. What has happen is odors in the sub-structure go away.
See the PDF... I put this in my reports if we find poor ventilation. Cost of install is about $ 1,000.00 Best Ron |
A smell is usually caused by some type of moisture which causes some organic matter to grow, such as bacteria. So then what is causing the moisture?
Many tell me how wrong I am and do not know what I am talking about . Stay tuned its starting to happen now . Need help on inspection call my cell 613-827-2011 Questions ( I like email ) Roycooke@hotmail.com "All that is necessary for the triumph of evil is that good men do nothing"----- - -Edmund Burk Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. http://www.nachi.org/forum/f5/intern...html#post90964 |
If an attic is properly vented with outside air, would the attic not have more upward pressure then downward pressure created by a crawlspace fan?
If there is a negative pressure in home the air will go to the least presure . Many things can cause lower pressure in home like Dryer, bath fan fire place with a fire, Power water heaters, Genair stove fan, window in home open on down wind side of home .
Depending upon the conditions (outside wind, temperature, ht of the bldg, etc) a negative pressure in the attic could draw air from any opening to it...including bypasses that originate in the crawlspace. It is odd to me that there would be a mold industry standard such as this since creating a positive pressure in the crawlspace (I'm assuming that the fan is drawing air from outside of the crawlspace, here) would force the air/spores through bypasses throughout the house. Think of a laundry room directly over the crawlspace with penetrations in the wall that would connect to the crawlspace (electrical receptacles, plumbing for pipes and stacks, etc). Operating the dryer, itself, would create enough negative pressure to fill the entire room with crawlspace air under these conditions. A fan inside the crawlspace that was simply circulating the air would not have this affect, IMO. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
wnapier is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can't speak directly to your crawlspace question but two houses ago (an 1890 built balloon framed farmhouse colonial) my big-arsed whole house fan would pressurize the attic and the excess would go down to the basement through the wall cavities and back up into the house when I opened the basement door.
You could even feel air coming out of some of the electrical outlets on the living levels when the basement door was closed. I ended up adding attic ventilation area, and would leave a basement window cracked open a little to be safe whenever we ran the fan. Al in TN |
I think almost every home should have on of these installed. there is always dead air spaces in all sub-structures. move foundation ventilation system are of poor layout or the front of the home is block by the garage the front porch/steps and then bushes. then if you look at the back of most home we see large decking systems then the sides of the home have a fence 5 feet away from the side walls. poor air flow. Best Ron |
We been having good results with crawlspace fans, just like Ron has.
| Return air from crawl space | WHI | Inspecting HVAC Systems | 11 | 1/9/12 7:43 PM |
| Sheetrock interior walls visible from crawl space? | jfunderburk | Structural Inspections | 13 | 7/17/10 12:49 AM |
| Crawl space entrance question | dnasser | Structural Inspections | 17 | 4/5/10 7:04 PM |
| Mold in crawl space | prussell | Structural Inspections | 4 | 3/10/08 12:53 AM |
