Old 5/14/07, 3:58 PM
sberlett's Avatar
sberlett sberlett is offline
Please Note: sberlett is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Crawl Space footing
On an inspection today of a condo with crawlspace, the floor in the crawlspace has a partial membrane with pea gravel. However all around the perimeter the footing tile is exposed and not covered with pea gravel. To me this is just not right, but would like other opinions and possible links to verify if the pea gravel should cover the footing tiles. First time submitting pictures, hope it works.
Thanks in advance, Steve
crawl-space-footing-exposed-footing-tile.jpg   crawl-space-footing-exposed-footing-tile-2.jpg
Old 5/14/07, 4:27 PM
ekartal6 ekartal6 is offline
Please Note: ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Crawl Space footing
I don't see the exposed tile as an issue. I am concerned with a vapor barrier that doesn't cover the entire area.
Old 5/14/07, 4:58 PM
sberlett's Avatar
Erol;
Shoouldn't the vapor barrier cover the entire area, be sealed and then covered with pea gravel?
Thanks, Steve
Old 5/14/07, 10:08 PM
Peter C. Russell's Avatar
In the first picture it looks like the water rises above the drain pipe, how did it smell in there? it looks pretty clean.
Old 5/14/07, 11:05 PM
Steve,
The vapor barrier should cover the entire ground but I rarely but I rarely see them sealed.
Old 5/15/07, 2:08 AM
sberlett's Avatar
Didn't smell all that musty, but there were numerous puddles of water on top of the plastic. No visisble plumbing leaks. It did have a continiously running Fantech exhaust fan discharging out of one of the crawl space wall vents.
Old 5/15/07, 5:50 AM
Sure looks like the work was never completed.
What's the rest of the crawl look like?
Marcel
Old 5/15/07, 6:17 AM
sberlett's Avatar
PEX piping yanked out of its supports so HVAC could run flexible ductwork where they wanted. Ductwork improperly supported. Puddles of water all over what little vapor barrier there is. Lady just moved in in mid-February. Hire me to do a report to hopefully get contractor to come back and fix things.
Think she is in for a long battle.
Steve
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 7:43 PM
Gas flex line in crawl space Richard Seay Plumbing Inspections 19 8/12/08 8:12 PM
Crawl space in under house dnasser Structural Inspections 15 2/27/07 7:12 PM
Is Romex in a crawl space a problem? jtedesco1 Electrical Inspections 48 9/30/06 10:53 PM
