Inspected a house tonight with a crawl space. It was 4 ft. high. There were drain lines and water lines in it. Also the main water shutoff. It was a bi-level and the door to get in was in the floor under the hall steps. It had vents all around. My question is there was no insulation in the floor joists. I thought all crawl spaces required insulation on the floor joists. The walls were insulated.
John Kogel www.allsafehome.ca |
From what you say, I have to agree this is almost treated like interior space. Have no idea the rules in kentucky...come to think of it, we don't even have crawlspaces here...
Also : Insulation in crawl spaces and basements has not always been "required". Depends on the age of the house. Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
You won't find insulation in a crawl space in Florida either. Most crawl space homes here were built in the early 1900's.
David Sorge (USN Retired) FL License HI142 Infrared Certified Thermographer Inspect-It 1st of Northeast Florida Serving Jacksonville and surrounding communities 904-484-4847 dsorge@inspectit1st.com http://www.dsorgeinspects.com http://www.linkedin.com/profile?view...US&trk=tab_pro We see RED...InfraRED When we see RED... You see $GREEN$ Ask us how? |
I think its not there simply because Ky does not have a GC licensing requirement which in turns means you can pretty much build the way you want without consequences.
(they do have electrical, hvac & plumbing requirements) Was this an older home? |
I would much prefer crawlspace perimeter wall insulation. Run a heat duct or two down there and let the heat rise up through the floor...toastie tootsies. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
A conditioned crawl space would not have foundation vents. It sounds like what I would call a "split level" home and I would hazard a guess that the insulation you saw on the walls was a lower level living space interior wall.
I would say this, but would not make it a significant issue if its an older home: "No insulation was provided for the sub-floor. Insulating the sub-floor to today's minimum standard of R-19 is recommended for thermal efficiency." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Poly being applied to Basement walls | dvalley | Interior Inspections | 40 | 11/24/09 10:49 PM |
| crawl space insulation | krentz | General Inspection Discussion | 5 | 1/15/08 8:36 AM |
| Question about exposed styrofoam insulation. | mlong | Exterior Inspections | 9 | 12/21/07 8:33 AM |
| Insulation in crawl space and basement | jmondragon | Interior Inspections | 7 | 6/2/07 2:09 AM |
