Old 1/30/08, 11:54 PM
Erwin Cox Erwin Cox is offline
Please Note: Erwin Cox is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Crawl space moisture barrier
Does any inspector out there know of a code that requires 6mm moisture barrier on the crawl space floor?
Old 1/30/08, 11:59 PM
Default Re: Crawl space moisture barrier
I now have another question. I have been a member of NACHI for years but the above note says I'm not affiliated with InterNACHI. Is this now a saparate organization?
Old 1/31/08, 12:14 AM
Banned
In my part of Canada, there is, but where are you from?
Old 1/31/08, 12:15 AM
I'm from Indiana. We go by national building codes.
Old 1/31/08, 12:32 AM
Stephen W. Stanczyk's Avatar
You have signed in under a new profile. You are still on the active roster. Check with Chris at fastreply@nachi.org and he should be able to send you your old user name and password. Welcome back to the boards.
Stephen Stanczyk
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 8:43 PM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 7:45 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
