This condition was found at the very top of a few joists in the laundry area. Anyone ever seen anything like it? Causes? There was evidence of trapped moisture in this area (notice flooring nails), however, joist were intact, as well as areas in question. House built in '57.
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like damage from beetles. Did you see any insect activity or indications of active infestation? The joists may have had that damage prior to being installed.
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
No other signs of insects.
I agree, looks like WDI to me also.
I'm with Vince, may be damage prior to install.
Alabama Home Inspections www.thebirminghamhomeinspector.com Home Inspections in Birmingham, Montgomery, Huntsville, and Tuscaloosa. |
How would you comment on it? Additionally, what would you say about black stains around rusted nails. Rest of the crawlspace looked great, minus this one area under the laundry room, and it was all open to the rest of the crawlspace (not a separate area).
Another pic. I still find it hard to believe that it might be from insects, although I could be wrong due to location, and how uniform it is. Almost, seems like a condition with the wood itself, it was almost a "honey-comb" texture. Regardless, thanks for all the replies and insight.
It looks like a pre existing condition in the lumber, I've seen this before in discount lumber,good clear wood is getting harder and harder to find.
Have seen some wood that looked like this before in older trees.......the heartwood had just begun to rot. In this lumber, grading may have missed it or it was not graded at all. |
Any leaks at washer above?
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Take InterNACHI's WDI test. Some of that infested wood was imported years ago. Probably not active, but I would call it out, and suggest further evaluation if you do not have WDI certification.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
I had the seller (realtor) question my client why I reported this one the way I did. (further evaluation by a structural contractor or structural engineer). They claim they hired a contractor to make repairs prior to the inspection.
Bob Stephens RBI# 2587 Laurens, SC 29360 864-907-1284 www.united2inspect.com United Home Inspections, LLC is a licensed home inspector in South Carolina providing home inspections in these cities and surrounding areas: Laurens, Clinton, Fountain Inn, Simpsonville, Gray Court, Cross Hill, Joanna, Greenville, Greenwood, Ware Shoals, Woodruff, Union, Enoree, Newberry, Whitmire, Little Mountain, Prosperity, Irmo, Columbia, Fort Jackson Military Relocation and surrounding areas. |
Robert, is that a (double wye) tee in the back ground? What is it serving? Cleanout? Doesn't look right from here.
I'm thinking (hoping) it's for the central vac!
Its for the central vac.
| Holmes Inspection | dcolangelo | Canadian Inspectors | 20 | 3/12/10 4:57 PM |
| ? possible reasons for crawlspace mitigation | jeubank | General Inspection Discussion | 11 | 2/17/09 3:57 PM |
