Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/10/10, 4:00 PM
Doug Edwards's Avatar
Default Re: Damp Crawl Space
What if....they do everything you "suggested" and the problem does not go away or even gets worse?
- John Stuart Mill
Old 9/10/10, 4:51 PM
Sean Fogarty's Avatar
I would suggest you report the current conditions of the crawlspace and leave it up to someone else to fix the problem. Its not your job to tell them how to fix it.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 9/10/10, 10:47 PM
Over 75% of basement/crawl space moisture is due to problems outside the foundation; gutters, downspouts, terracing, poor window wells, vegetation, poor lot placement, etc.
Probably needs a full sump hole and drainage system installed, and do all of the above.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 9/11/10, 8:33 PM
Bruce A. King's Avatar
Originally Posted by ghancock2
I inspected a wet crawl space, on wall had negative grading, and some of the ducts had an organic substance. My remedy is to cover the access door and move to the inside of house, seal the stem wall, correct negative grade, dry the crawl space with fan, install a vapor barrier, and insulate the joist? Are there any suggestions to prevent moisture or change some of the suggestion I have made.
Be careful, many of these will need a sealed and conditioned crawlspace conversion to fully correct the issues in addition to other work. It could cost anywhere from $6k to $15k and up depending on the house.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 9/11/10, 8:59 PM
James E. Braun, CMI's Avatar
And that price does not included proper mold removal. Sad but true.
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 7:43 PM
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Crawlspace ventilation help pmassie Canadian Inspectors 47 3/2/10 9:54 AM
