jcundiff is a non-member guest and is in no way affiliated with InterNACHI or its members.
I had a client call for an inspection of a basement in a brand new home. Client is concerned about continuous dampness in the basement. The builder is ready to close but the client is weary. Here's the stats:
-Poured concrete walls with sprayed wp membrane -Walls poured early April -House built and "in the dry", basement floor placed first week of May. -Finish grade June 1 -No interior drain tile, exterior footer drains come into a sump pit and are taking delivering a constant trickle during dry weather. -Neighboring homes are bone dry Inspection June 11th- All concrete in basement is damp. Most corners are actually wet with liquid water. RH is 67% @ 68 degrees. Builder has placed two dehumidifiers which run non-stop and have not had much affect. Builder claims this is latent water from the concrete burning off. My experience is that most new basements are dry and the concrete chalking within a month. Builder did not allow me to photograph. Any thoughts?
I have no ideas for you but would be concerned just because he wouldn't let you photograph. Sounds fishy.
I would not buy this house.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
It might be nice to go down into the basement every now and then if
love the musty smell of fungi... John McKenna, CMI (TREC #4565)
Have many basements in Texas John?
They are sweating. The only possible way to know if it is sweating or leaking is to tape a piece of tin foil to the wet area of the foundation 12"x12" and the next day, if the surface of the foil is wet, it is sweating caused by moisture in the air. If it is wet under the foil, water is coming in through the concrete. I have a feeling that the moisture barrier might have been omitted under the floor slab, moisture or heavy sweating would be an indicator. Not allowed to take pictures does not sound good. I would advise the client that all necessary steps be taken to correct this problem before attempting to go further with this deal. Hope this helps a little. Marcel </IMG></IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Have to be careful when making quick judgement calls on something such as a new, not-fully-cured and dried concrete foundation. Outdoor conditions with ambient high RH air infiltrating or being delivered to the basement through a ventilation system such as an HRV can cause the high moisture levels or add to the ambient moisture from a new foundation's release of free water.
An example from the Canadian Portland Cement Association book "Design and Control of Concrete Mixtures": Preamble: While the surface of concrete will dry quite rapidly, it takes quite a long time for concrete in the interior to dry. 6" wall drying from both sides: Ambient conditions: 23 degrees C (73 F); 35% RH 850 days were required for the concrete in the center to drop top to 50%!!! So the bare walls and slab can be giving up quite a bit of water for months after pouring and cause a false call to be made. |
Nick: He can fix basement leaks from the exterior but doesn't usually talk about psychometrics and inherent concrete properties. |
They damp proof all the time and call it water proofing. I would have them close the house and run big de-humidifiers for at least a week or two, then re-test. The builder is blowing smoke. Don't let them buy until someone, with licensed authority, and insurance to back them up if they are wrong, puts it in writing. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
I've been around new construction for around 20 years and never seen a basement with such high humidity (resulting in condensation) that an air conditioner and a dehumidifier could not take care of after the house has been closed up. I just have a hard time believing that this much humidity can be primarily coming from the foundation and/or basement floor.
The inspector can not tell the buyer to not buy the house but he can tell them when something is not right and refer it to a specialist. And that basement is not right. |
| something else to chew on | john bubber | Structural Inspections | 662 | 1/31/12 2:33 PM |
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 2:43 PM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| Basement construction | kmartin2 | General Inspection Discussion | 8 | 8/15/07 8:58 PM |
