what's the maximum height of a deck post before cross braces or kickers are required?
| Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
2 feet!!!
parallel and perpendicular to the beam at each post as shown in Figure 22. When parallel to the beam, the bracing shall be bolted to the post at one end and beam at the other. When perpendicular to the beam, the bracing shall be bolted to the post at one end and a joist or blocking between joists at the other. When a joist does not align with the bracing location, provide blocking between the next adjacent joists. Decks attached to the house do not require diagonal bracing perpendicular to the house. |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Decks greater than 6 feet above grade should have diagonal bracing from posts to girder, and from posts to joists.
See www.nachi.org/deck-inspections.htm Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
Decks greater than 2 feet above grade shall be provided with diagonal bracing. Go to section 14 under free standing decks. Forum limit does not allow PDF posting directly so go here and download the guide for deck construction. http://www.google.com/url?sa=t&sourc...fUGN7yAOczhVbQ |
Dido Bob.
| First 20 members to post win How to Perform Deck Inspections book. | gromicko | Exterior Inspections | 41 | 12/21/09 9:23 PM |
| Another deck Collapse | rcooke | Canadian Inspectors | 11 | 3/30/08 8:03 AM |
